E-Class (W211) 2003-2009
E500 Suspension Life
Old Apr 2, 2008 | 12:11 AM
Scambo's Avatar
'13 E550 W4
Anyone know the general lifespan of the stock E500 suspension parts? My car has 77K miles on it and I'm wondering if I need to proactively consider replacement at this time. Any information is appreciated.
Old Apr 2, 2008 | 08:06 AM
vettdvr's Avatar
03 E500 and Corvette
Front ball joints failed on ours at 72000 miles. I would look at them for wear.
Old Apr 2, 2008 | 09:06 AM
Benz-O-Rama's Avatar
My right front ball joint failed at 55K miles. Left one is still good.
Old Apr 2, 2008 | 09:28 AM
Scambo's Avatar
'13 E550 W4
Yup, already did ball joints at about 70K miles.
Old Apr 2, 2008 | 11:09 AM
georgedaman's Avatar
GL350
rear shock at 75K
Old Apr 2, 2008 | 12:38 PM
daddcap's Avatar
2014 S550
Right Front Strut
I had to have my right front strut replaced at 51000 miles
Glad i Had the MB extended warranty.
Old Apr 2, 2008 | 01:25 PM
W Cole's Avatar
makes your daughter horny
Are these are the joints in the upper control arm? They look easy enough to replace..
Old Apr 2, 2008 | 02:26 PM
Diesel Benz's Avatar
Both have had bad parts but I think the lower joints were more prone to fail. It was a bad batch of parts, now that this car has survived this long, I would assume it has good joints.
I would inspect all the joints carefully, if they are good, then just wait until they start showing wear. The airmatic protective bellows should be checked too but if they are good, I would not do any proactive service.
Old Apr 2, 2008 | 07:02 PM
motioneffects's Avatar
Thrust arm bushings L+R, lower control arm bushings L+R, ball joints L+R, Tie rods L+R. shocks may leak all around. Airmatic-pump likes to go alot, valve blocks have issues. For those who lower their car-thrust arm bushings go very quick.
Old Apr 3, 2008 | 08:12 AM
vettdvr's Avatar
[QUOTE=Diesel Benz;2743020]Both have had bad parts but I think the lower joints were more prone to fail. It was a bad batch of parts, now that this car has survived this long, I would assume it has good joints.
QUOTE]
I have learned, I will believe it was a bad batch of parts when I have more than 70,000 on the new joints and they are still servicable. Until then I have to believe with so many ball joint failures it is design.
Old Apr 3, 2008 | 08:57 AM
Actually the bad batch failed easily at 25 000 to 40 000 km. I must have been thinking about 70 000 kilometres but this was miles. That makes well above 100 000 km. In my opinion, modern suspension parts are not designed to survive without service a lot more than this, perhaps 150 000 to 250 000 km. A "better" design would give worse dynamic performance.
70 000 miles is a bit low for wear on good parts.
But I thought the question here was more about proactive service. Would anyone suggest changing suspension parts before any wear has been observed?
Old Nov 22, 2008 | 05:04 PM
crazeazn's Avatar
C55
Sorry to bump an old post but I had a question regarding this. I have a 04' E500 with around 21k miles (still with original tires which I will be changing out soon) I did a finger gap check and my right rear wheel gap is 2 fingers (3 fingers between onthe other three arches). Would this be a strut problem? When activating ride height, the car does elevate on all 4 corners but the gap is still there. Any help would be appreciated. I have aftermarket extended warranty but I don't believe its considered a wear and tear part.
Old Nov 23, 2008 | 05:55 PM
crazeazn's Avatar
C55
bumpy
Old Nov 23, 2008 | 06:35 PM
tashakes's Avatar
2020 GLE350
I would not worry about it, mine has always been lower on the left rear than the right rear, you will need to worry when you get the red warning on your display saying to stop the car because the suspension is too low. My front right strut was replaced with less than 40K miles on them, now I am at 65K and no other problems have come up.
Old Nov 24, 2008 | 11:05 AM
TTopJohn's Avatar
Any experience with having the air struts and air pump covered under an extended warranty?
Most policy language excudes "shock absorbers." If I were looking to avoid paying a claim, I think I could make a pretty good argument that the air strut assembly, though it combines the functions of a spring and a shock into one unit, is in fact a shock absorber and therefore excluded.
Now on an exclusionary policy, I've never seen "air pump" listed as an excluded item, so I think you'd have a good shot at having an air pump replacement covered.
Old Nov 24, 2008 | 09:32 PM
nycturbovr6's Avatar
front passenger shock at 51
Old Nov 25, 2008 | 11:35 AM
cunnincr's Avatar
2001 E320, 2003 E500
Left front air strut replaced at 69k. Ball joints and Thrust Arm bushings 72k. The air strut was by far the most expensive @ $1,700.
