Ran over piece of steel!
Could not get out of the way because SEMI TRUCKS on each side as usual.
Underneath my driver side door - Can NOT see it unless you look underneath) was a 3 inch cracked hole and piece loose.
I called Westmont MB where I bought my car, he said "If you cant see it, does not do anything to your car". I am worried about the under body of the car.
What are your feelings? Can it do anything bad to my E500?
How much to fix?
Really appreciate your thoughts...
How much to fix?
Maybe less or more.
But you won't know exactly how much it would cost you until you get an estimate from a body shop.
How much to fix?
If the crack is in the frame or the door sill, a good body shop can usually 'tack' it...
Shouldn't cost much at all for a simple tack or two...
Yanno?
