Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: How to Replace Brake Line
Step by step instructions for do-it-yourself repairs
"Brake - Visit Workshop" message = stop light switch = $10 part / 10 minute Easy DIY
#126
OT: dealership told me my brake pads were down. I refused to get them replaced. A whole 4 years later they were actually down and the sensor triggered! This is something I reported to MBUSA back then. For me it falls under the category let's scam this customer some money out of his pocket!
#128
Good luck!
#129
A big thanks to this post. My sister in laws 2006 E350 had been showing the brake wear message for 9 months now. All pads and sensors were new though. I bought this part for $10 from my local stealer with a shop discount and installed it in less than 5 minutes. No more message!!!
#130
2004 E320
I have this message (not red) and installed new switch, but I still have the message. Do I have to get the code cleared with the diagnostic tool, or would it have gone away if it was the switch?
Please tell me that this isnt indicative of it being the SBC, as my SBC warranty just expired 4 DAYS AGO.
#131
4 days is ok, they have leverage! Good luck or stop by like I said
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#133
2004 E320
If the switch is the culprit will the light go away on its own, or will the Star Diagnostic Tool be needed to do a reset? I have not been able to find a definitive answer to this question.
#134
Another part that you should check is your Aux Battery. Front passenger side underneath the passenger compartment air filter box. It's one plastic nut that needs to be loosened to get to the battery. If the battery's voltage is the same with idling and turned off motor, the fuse or relay is bad and you'll see the same error message (which is a generic let's bring the car to the shop message) in your IC.
#135
You might consider replacing the SBC unit now as preventative maintenance since it comes with a new accumulator. That might be a better, less expensive, option in the long run considering it's very probable you'll need to replace the SBC at some point down the road anyway and you're beyond the ten-year extended warranty period. Either way, it's going to cost you a chunk of change. How long you plan to keep this car is going to be a key factor in determining what you decide to do at this juncture. Good luck
#136
2004 E320
The code I got was C249F I was told this means a SBC Control Unit. Can anyone verify that this information is true?
The local Dealership was unwilling to fully assist me with this, and unwilling to initiate a claim with Mercedes USA. As they said I was 12 day past the 10 year mark.
By the time the dealer had availability (1 week after my call) to see my car I was 12 DAYS past the 10 year mark and the dealer basically told me I was screwed and the best they could do on a $3,039 repair was to give me a 20% discount. Also note that my light came on prior to the warranty expiring but I went out of town and have flight records to prove that I was out of town for for 2 weeks prior to the car being seen by Mercedes.
I have since initiated a claim with Mercedes Benz USA and am awaiting their response. Has anyone had success with Mercedes Benz USA stepping up to the plate?
#137
#138
esp/abs/service brakes visit work shop
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#139
OBD scanner won't help you much bc if you get the red visit workshop message in your cluster display that means it's something MB related/internal and is not part of the OBD standard hence won't be stored as one of the Standardized OBD codes. Let a dealership perform a quick test with Star Diagnosis instead of letting us do the guess work. If you're in San Diego I'll do it for you.
#140
codes pulled
6210= abs
6230= esp
p2403 = left front wheel speed sensor * now fixed *
And now the codes I don't know or can't find info on it
43af = ???
9051= ???
So I fixed the code p2403. My mechanic cleared the codes and when I left his shop I came back on so I don't know if maybe the other codes need fixing as well any help is appreciated
#142
trying to diy as i do most of the time
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Hey thanks for the heads up and that's why I'm here trying to get some answers I thought that's why this firm is here NO......
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
codes all in white NOT RED
6210 means abs error message abs malfunction visit workshop
6230 means ESP error message ESP malfunction visit workshop
43af means front speed sensor message not yet displayed but soon to be a CEL code P2403 when pulled from obd2 code scanner
P2403 means left front wheel speed sensor
And last code was 9051
9051 is BCM consumer shutoff stage 1 what that means I'm still looking think it has to do with aux battier dying as far as I can see so I will have my indie pull the codes with his giant computer scanner NOT just an OBD2 code scanner it pulls the same codes as the Mercedes Benz star diagnostic scanner so I will see if all codes are still there
Thanks for any help
#143
Thanks for any help
It has nothing to do with aux battery. This battery is there to make sure your SBC brake system has enough electrical power.
Aux battery cannot start your engine or cross charge your main battery as some people (still) believe.
#144
Hi Mackhack,
I am also in San Diego. I just got a message on my w211 about "Brake - Visit Workshop."
I saw that you have star diag and I was wondering if you I could pay you to read the code for me?
#145
Or go on my website and send me a message through "contact me".
#147
replacing brake light switch didn't fix the problem
Not for me. I replaced the brake light switch in my 2004 e500 but the "Brake - Visit Workshop" message remained. And I already replaced the SBC in 2005 during the recall.
What else could be causing the message to appear?
Thanks,
Ken
Thanks,
Ken
#148
My issue was the accumulator (round "ball") attached to the SBC pump. Diaphragm inside was bad. Dealer would not warranty this item. Had replaced at independent and all is well. The part is #20 in attached diagram. Good luck.
#149
Thanks for your reply. How did you know it was the accumulator? Did your car tell the independent's computer what the problem was? What was the cost to replace this?
Thanks,
Ken
#150
The independent shop I took it to was able to test and confirm. Cost to replace was $450. $350 for part.
