E-Class (W211) 2003-2009
Rear door ashtrays broke off - looks like can't replace, only new whole door panel?
Old May 26, 2008 | 08:58 PM
jeffsnavely's Avatar
2004 E500 4matic Wagon
From looking at the EPC it seems like there's no way to replace/fix this without replacing the whole interior door panel.
These are a terrible design - both sides broke off with not much force when they got caught on my pants and my son's pants.
Old May 27, 2008 | 01:47 AM
Diesel Benz's Avatar
Which part actually got broken? Odd if you've had an issue on both sides while I have not had any on two similar cars.
Anyway, EPC shows which parts can be bought separately if you don't want to try to fix the broken parts.
http://www.detali.ru/cat/oem_mb2.asp...SGR=075&SGN=06
Old May 27, 2008 | 09:54 AM
Part 330 "Ashtray" broke off...
it's only held in by a spring and some small plastic things.
As you can see in the diagram, it mounts directly into the whole door panel. I now have a gaping hole in each rear door.
Old May 27, 2008 | 03:40 PM
phatmitzu's Avatar
2005 E55
The housing can be removed and replaced by its own. I had mine replaced by my MBtech. It only took him 2 mins. The part costed me ~$40 if I remembered correctly.
Old May 27, 2008 | 04:00 PM
That would be great - Thanks for the info...
on the parts diagram above there's no separate part listed however -- could you possibly find your record for this repair and find the part number?
Old May 27, 2008 | 05:04 PM
konigstiger's Avatar
'71 Pinto
Left ashtray part #A2118100930, right A2118101030 + color code extension
https://mbworld.org/forums/showpost....34&postcount=7 (pdf - page 2)
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
