E-Class (W211) 2003-2009
Help me!! locked key in trunk
Old Jun 8, 2008 | 09:37 PM
tpatel9's Avatar
03 E500
So i did something so dumb. I closed the trunk with my key fob inside. I called AAA and they unlocked the door for me but I cant unlock the trunk. Is there any over ride or any way to get in there or to open it up? Its night time now and the inside lights are on and wont go off. If I wait for mercedes tmw I'll have a dead battery too. Any thoughts???
Old Jun 8, 2008 | 09:48 PM
Benz-O-Rama's Avatar
Call MBUSA and see if they can unlock it via TeleAid. I think they can unlock doors, so I don't see any reason why the trunk wouldn't unlock.
**Wait** I just read your post again. If your doors are unlocked, the trunk should be unlocked too. They lock and unlock together. Plus you could always hit the 'trunk open' button on your door.
Old Jun 8, 2008 | 09:50 PM
starcar's Avatar
1994 E320
What about your back seats, do they fold?
Old Jun 8, 2008 | 09:54 PM
6MTUA5's Avatar
99 Acura 3.2TL-P 6MT
:werd: Then you can pull the emergency cord from the trunk to pop it.
Old Jun 8, 2008 | 09:57 PM
starcar's Avatar
1994 E320
I forgot to mention that! Thanks 6MTUA5!
Old Jun 8, 2008 | 10:05 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Does the trunk release switch on the driver's door not work? Did you manually lock the trunk with the metal key?
Old Jun 8, 2008 | 10:06 PM
tpatel9's Avatar
03 E500
The "unlock" button on the dash does nothing and neither does the trunk button on the door. My seats dont fold down either. I tried all these things. Its very odd. The radio turns on as do the headlights but there is no power it seems to the unlock button and trunk open on the door.
Old Jun 8, 2008 | 10:14 PM
starbrite's Avatar
2004 E320
Use the metal key, that'll work.
Old Jun 8, 2008 | 10:15 PM
AsianML's Avatar
2007 E63
I don't think TeleAid will work unless he's had the new module put in for the digital signals.
Old Jun 8, 2008 | 10:33 PM
tpatel9's Avatar
03 E500
I dont have the metal key either
Old Jun 8, 2008 | 10:48 PM
QQQ's Avatar
QQQ
MY2001 C320
Try lock and unlock the car from inside and then press the trunk open button.
Old Jun 9, 2008 | 08:36 AM
vettdvr's Avatar
03 E500 and Corvette
The metal key is IN the KEY FOB.
Old Jun 9, 2008 | 10:04 AM
Davel's Avatar
03 Eclass, 03 BMW 06 Porsche Cayman S, 03 Harley Davidson "bored & stroked"
if someone has used the metal key to turn the lock to the override position (prevents valets from going in the trunk) you cannot open the truck via the trunk release inside the car, nor can you lower the seats since the release is inside the trunk. He needs to take his vin number and ID to his dealer and get a metal key made. MB is very strict about this (rightfully so) so be prepared to prove ownership of the vehicle...
Old Jun 9, 2008 | 07:11 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
The unlock buttons arent working because the alarm is still armed. You need to call roadside. There is a way to get into the trunk that they should know. Should take them about 20 seconds...
