Sound from HK and Ashtray insert
The ashtray insert is a mystery problem. I have no idea why some have them and some don't. I had heard of the rubber mat insert on this board before I picked my car up. I looked in the glove compartment, where it was supposed to be and it was not there. I told my salesman that I wasn't leaving without one. He had never heard of it either. We looked in cars on the floor and I found one in a E-320 along with the sun roof crank that I was also missing.
I would suggest you go back to your salesman and kind of look thru the inventory until you find one. I don't think you are going to get one any other way. My salesman said he asked the parts manager and he said he had no documentation on it and did not know it existed. It is a real good thing to have.
Good luck...let us know how it went.
Ed
I want to check my connection speed on my dsl but have lost the site address for checking speeds. I did have a couple and they worked pretty well but can't find them.
Among others, MBWorld seems to be getting slower and slower.
I don't know if it is my connection or MBWorlds bandwidth.
Anyone know the site address for checking dsl connections?
Ed
http://bandwidthplace.com/speedtest/
http://bos.speakeasy.net/
http://www.cable-modem.net/features/oct99/speed.html
http://www.numion.com/YourSpeed/Checkup.php?L=tw
http://home.austin.rr.com/bc/bandwidth.htm
Way off subject:
Ed
Try this link: click on "Speed Test"
http://www.dslreports.com/tools
I hope Zandorf finds his ashtray mat and gets some feedback on the static on his audio. Didn't mean to change his thread, but do appreciate the quick help.
Ed
Nick
Are you using Logic 7 when experiencing your static problems? If so, the issue is probably do to weak signals (even though they may APPEAR to be strong). The Logic 7 setting decodes surround channels from typical 2-channel sources to 'enhance' the listening environment. If the signal coming in has poor quality, you may not be able to hear it in a typical 2-channel stereo mode. The Logic 7 wil amplify the inefficieny as one or more of the channels decoded may be comprised almost solely of the static sound.
Nick
Tried calling two parts departments with that part number Briar gave. Both departments said it came up as a "liner" Neither of them had it and said that it would have to be ordered. One of them said it costs $5. Now I wonder why I wasted my time. I wonder if other people in New York ran into the same problem with this ashtray liner. Anyway, I couldn't give a rat's *** anymore, i'm done with this ashtray liner nonsense.
Ed
I have, since then, not been able to play cds in the changer. I cannot add or remove cds and the changer itself is completely unresponsive even after several key/power cycles of the system.
My radio now doesn't even recognize that the cds are in the changer as it once did.
My guess is that there may be a burned out fuse, and that the static was an indication of the fuse blowing.
Right now, I'm trying to figure out how to get into the front fuse panel but, after reading the manual, I am unable to release the cover panel. I don't want to risk damaging the panel retainage clips. Can anyone indicate wheather the fuse for the 6cd changer is in the front panel or the set in the trunk.
Thanks for any info.
