E-Class (W211) 2003-2009
E500 and Valeo Radiator
Old Jun 17, 2008 | 09:20 PM
captrivers's Avatar
03 E500 Sport, 03 Eddie Bauer Explorer, 06 Pro Street Chopper
The problem with the radiator fluid contaminating the trans fluid is concerning me. My production date was 07/02 with the Valeo radiator. I hadn't gotten under the car to check if they used the old crimping method to assemble my radiator. I am taking it that it was do to my production date. I have 42,000 miles on the car and are wondering since I hadn't had a problem. Can I still expect for this to happen? Was all of the Valeo radiators installed in this model problematic? Can I be one of the lucky ones and will not see this prob?
captrivers
Old Jun 17, 2008 | 09:52 PM
ohlord's Avatar
Valeo
radiators up to production date sept 03.Anything can happen at any time so best to have it inspected and the fluid tested.Cheaper to do that then have to flush the two systems and all that jazz.Or worse have to get a new trans.
Don't recall a recallbut the dealer will inform you if it is.
at 42k miles it is time to have the trans fluid and filter changed so get it inspected when the shop does the fluid drain.
ohlord
Old Jun 18, 2008 | 09:44 AM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
I recommend rather than having the fluid tested & inspected, to change the radiator to the updated one. Even if your fluid cks. out ok, that does not eliminate the chance that the flawed-by-design rad. will fail any day. BIG preventive work compared to a contaminated transmission unit. (Unless u're covered under warranty)....
Old Jun 18, 2008 | 01:06 PM
Piranajoe's Avatar
2003 E500
captrivers
I have the same prod date as you with no problems or contamination in the tranny but I changed the radiator for the new style to avoid future problems!
Old Jun 18, 2008 | 03:30 PM
b_rashed's Avatar
2007 S550 (S65 Package)
trust me go and change it. i had the problem with my car and i went to my mechanic and so far hes changed 4 including mine in the past 8 months.
Old Jun 18, 2008 | 09:38 PM
nikon's Avatar
E 63 AMG S
+1
Old Jun 18, 2008 | 10:44 PM
gnma's Avatar
IIRC, changing the rad. in my Supra was easy. Remove top brackets, upper/lower rad. hoses, and tranny cooler lines. Due to a mech. fan, I did not have to remove it. It was VERY easy. Don't know about MB though, at the very least, prolly have to remove the electric fan(s), but that should't be a biggie. Anyone replaced a rad DIY on the W211?
Old Jun 19, 2008 | 09:37 AM
Benzo1999's Avatar
2003 E500 Sport, 1999 ML430 & Regal 402 Commodore
Anybody get a price on a replacment rad? I'm considering doing the R&R myself.
Old Jun 19, 2008 | 11:24 AM
captrivers's Avatar
DIY tips for radiator replacement
gnma, very good subject.
Can we get some tips/pitfalls/experiences on this radiator replacement. There's plenty of room making it seem painless.
Sounds like a much needed DIY thread for this model with a production date prior 09/2003.
captrivers
Old Jun 19, 2008 | 11:44 AM
captrivers's Avatar
Benzo1999, PM RBrenton.
Old Jun 19, 2008 | 01:24 PM
gnma's Avatar
I've just posted a "how to remove rad?" question over in the tech. section. Also ck. this out:
http://www.detali.ru/cat/oem_mb2.asp...SGR=015&SGN=01
Its basically a parts diagram, but these can be very useful in determining how to remove/install the part. I THINK its for a W211. Match it up, and you'll be able to tell. Keep us posted. and good luck!
Old Aug 3, 2008 | 02:52 PM
gisham's Avatar
E500
just checked mine and it is a valeo A 211 500 0202
any way to tell if it has been replaced by previous owner? can you visually tell the difference between the old defective radiator and one that has been changed out?
Old Aug 3, 2008 | 05:04 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by gisham
just checked mine and it is a valeo A 211 500 0202 any way to tell if it has been replaced by previous owner? can you visually tell the difference between the old defective radiator and one that has been changed out?
You can readily tell by comparing the crimping method depicted in the associated DTB (MBUSA bulletin). PM your email address and I will forward a copy of the DTB. FYI radiator part # A2115000202 is replaced by A2115003102.
Old Aug 4, 2008 | 09:03 AM
gisham's Avatar
E500
I found a copy of the bulletin. Thanks for your help- I think im gonna just buy an aftermarket warranty for the car rather than start replacing parts that are not broken.
