Center Speaker Rattle (Harmon Kardon)
I have an 07 E350 Wagon 4Matic which I really love. Only issue that hasn't been resolved is a rattle, vibration or buzz coming from the center speaker on the HK sound system. It happens primarily with female vocals, acoustic music and sometimes with spoken speech...ie News/Traffic.
Has anyone else experienced this?
They've replaced the center speaker, and added foam/adhesive to the speaker grill. Once they did this, I listened to it at the dealer and it was fine. Later that day, it started acting up again. It seems that if it's a very hot day and the dashboard heats up, the speaker stops rattling and performs as designed. First thing in the morning, or anytime the dashboard hasn't baked in the sun, the vibration is back.
Has there been a TSB on this or a solution that has been applied to these cars?
I also own an 08 E-Class sedan with the HK sound system and it has never exhibited this ever. Which is very frustrating as I primarily use the wagon.
Any advise would be great or anyone else who's experienced this.
Yep, there's a TSB for this. If you search, you'll probably find it. I'm sure Konigstiger will be chiming in soon with the TSB if you can't find it. You could PM him if you're in a hurry.
Oh, and where did you get the power folding mirrors? Where do you have the switch/control for them installed? They weren't ever a factory option were they?
The hardest part of the install was taking off the old mirrors. They're spring loaded and the screws that need to come out are behind the mirror. So you have to compress the mirror assembly in, while you loosen the bolts.
The wiring is all there. The connector for the two different switches is the exact same. You just need to pop your door panel off, unplug it, plug the new one in, put the door panel back.
Then you just take it to the dealer to get them programmed to open and close automatically.
You could either request that they apply felt under the flap mechanism on both sides (reference DTB P-B-82.62/537 OCT06 – release for MY03) or cut to the chase and request they replace the ventilation screen #155 (part # A2118310036 + color code) and nozzle #152 (A2118301954 + color code) under warranty since P-B-68.10/53 repair failed to resolve temperature sensitive rattle/vibration/buzz.
