DIY: Installing a new Changeover/Heater Control Valve
One other item take off the wiper motor assembly it is three bolts and disconnect the electrical connection to the wiper motor makes the job much easier.
PART:
Cheapest source for part I found was MBOnlineParts.com ($31.50 + $9 = $40.50)
http://www.mbonlineparts.com/parts/2005/MERCEDES-BENZ/E55%20AMG/index.cfm?searchText=211+832+05+84&siteid=215843&y ear=2005&make=MERCEDES-BENZ&model=E55+AMG&submodel=&vehicleid=1431058
If you can’t find the part, search on the part number without the “A” (i.e. “211 832 05 84”)
REPAIR:
Wiper Arm: found it a little difficult to remove the driver’s side wiper arm. Trick is to pull the wiper arm off of the glass a little (as if you’re about to clean the windshield). This will relieve tension in the mounting bracket and you can remove it at that point.
Plastic Rivets: I didn’t find it hard to remove and replace the plastic rivets w/o breaking them. Technique I used was to unscrew with one hand and slide something sharp under the screw part with the other hand. I used a small flathead screwdriver for that. Through unscrewing and prying up, I was able to get it to the point where I could use a needle nose pliers and pull the whole thing out.
Plastic Plugs on Cover at Base of Windshield: these only come loose with a lot of force. I pulled a little from the top while pushing on the back with the tip of a pry bar. Worked well. Didn’t break any. Just make sure you aren’t using the pry bar as a lever by pressing against anything else in there cus it’s all fragile stuff.
Wiper Motor: I followed the advice of another forum member who wrote to take off the windshield wiper motor. I very much agree that it’s worth the minute or two. Also don’t forget to connect the wiring harness to the motor when reassembling!! Not saying I did, tho! :-P Won’t admit to anything!
Disconnecting Stepper Motor (a.k.a. changeover valve): before disconnecting this, you may want to take the cap off of the coolant expansion take. I don’t know if this will minimize the amount of coolant flowing out of the stepper motor, but it might. Easy to do, so it’s worth a try. Also, the first part you should disconnect is the part pointing to the front of the car (to the front of the firewall). There’s less electronic equipment there, so it minimizes chances of coolant flowing out causing damage. Lastly, when you disconnect the hose that points to the right of the car (the one connected by a clamp), have plenty of paper towels stuffed in beneath it. This will keep coolant from going everywhere.
Other info: http://www.buellwinkle.com/HVAC-W203.pdf
THAT’S ALL! THANKS AGAIN, W211 Ryda!
I found the part for only $30 at getmercedesparts.com which is MB of Annapolis, MD.
The 3 screws to remove that electrical box are t20 not t25.
A standard hook and pick set like pictured here >> http://www.craftsman.com/shc/s/p_101...4&blockType=L4 is all that's needed to remove all the clips. This is an item that should be in everyones toolbox.
After you install the new valve and before you re install the shroud be sure to rinse underneath the valve to wash out the coolant that leaked on to the paint.
Finally clean the bottom of the windshield underneath the shroud. My glass had some dirt buildup. Also be sure to clean underneath the rubber seal/ lip that sits on the glass. Their tends to be buildup that gets in between the glass and the seal. This will ensure a nice tight seal and help keep dirt out.
Here is inside my defective unit:
First of all, THANK YOU for this thread. There is no WAY I could have done this without the great writeup and pics.
Has the Forum ever considered a Wiki to organize these pieces? I frequent another forum, the SL Group, for Pagodas (W113) and the Wiki is a really useful tool.
Couple of notes for this repair:
My problem was not too much heat. It was no heat. Same root cause, which was corrosion from leakage inside the motor housing causing the control unit to freeze and burn out motor.
I did not need to remove the whole firewall shroud. I left the driver side wiper arm in place, and just pulled the shroud about 3/4 of the way free. OK, so it was because I could not get the wiper arm off and did not have the right puller, but it was fine and did not impede the R&R.
As a couple of posts said, 1.) you do not need to install with the clips open, you can pop the valve body on with the clips closed and 2.) that spring clip/ hose clamp is a pain and it is, imo, better off replaced with a screw-type clamp which I did.
The valve body can be oriented 1,000 ways to R&R, but only one way works! (at least for the E500). You will need to cycle the wiper linkage to get maximum clearance, then get the body clear by bringing it out with the electrical connector body first and facing rearwards.
The plastic connectors pinning the shroud to the firewall are fragile, plan on replacing vs. reusing at least 2 of the four. I only salvaged 1.
You will need a heavy duty coat hanger. The clips are in very tight.
Thanks again for this great repair note, what a great forum.
Greg from Atlanta
Performed this surgery on my wife's 2004 E500 4-matic last night.
Her symptom was no heat.
Took about an hour and a half (15-20 minutes spent trying to retrieve one of the wiper linkage nuts that fell under the driver side fuse box and then onto the belly pan).
Observations:
-Purchased the valve from Mercedes of Westmont for $41 (suprised me too).
They needed a VIN because apparently there are TWO versions of the valve - one with a bypass of some sort. This one did not need it.
-The coathook idea is brilliant and was used to get the bottom connection to the heater core off.
-Definitely worth the extra couple minutes to remove the wiper motor assembly.
-Very little coolant came out of the lines (but coolant level was good). It was a cold car (not driven for 48 hours) so I'm not sure if that had something to do with it.
-Biggest pain in the rear was trying to gently pry the palstic shield off the windshield without breaking the pastic rivets, and then re-applying it so it sealed.
Excellent write up, thanks for the details.
E Class estate cdi avantgarde (w211) 2008 model.
Peter
Peter
I agree the front hose can be hard to move. Did you manage to remove the clip for the front hose? If so, then the use of a large pair of channel-lock pliers to rotate the hose adaptor fitting just a degree or two relative to the valve body, may do it. You need to break the years-old affinity the two plastic parts have developed for each other. The hose adaptor/plug/elbow is tougher than you think so I doubt you'll break it. It is clearly visible in the pics if you aren't sure what I'm talking about.
The thing that really got me bad was after my friend disconnected the hose that I couldn't disconnect, a lot of coolant spilled out. We ended up refilling the coolant reservoir with distilled water to get the coolant level back up. Once we started the car and turned the heat on... it was still blowing out cold air. We had to drive the car around for a bit in order for the air to start blowing hot.
For the record, I opened my old one as well, and noticed one of the solder joints was disconnected... seems like a simple thing to repair with a soldering iron, but I had already purchased and installed the other one:
Thanks again for the great write up!
) the air is not so cold like in the right side (passenger seat
), i think it makes cold by simpaty ,anyway its a teperature diference about 5degree Celsius more or less ! Can You Tell Me please what is wrong?!? I just refill the instalation with freon (on the right side seems like in Alaska) front and back , the fun is working verry well No noise,No smel inside cockpit,a friend of mine check the hole car with a laptop and No problem with AC(clima),the car itself have 90.000miles(141.000km) Please Some HELP & THANKS !!!
