DIY: Installing a new Changeover/Heater Control Valve
Edit: Looks like my problem is fixed! As others have said, removing the wiper assembly is easy enough, and gives a lot more space to work.
Does anyone have the part number for the large plastic trim piece under the wipers that runs the width of the car? Mine is old and has chunks missing where it connects to the window.
Also, does anybody have a tutorial f
to replace the dual valve (I believe it is under the front mudguard)?
Thanks,
daniel
Logged on here Friday night and found this tread. Prepared to do the repair this week however heat returned yesterday on my drive back,but not for about an hour.
Wife drove car Friday morning and whwn she camy get something to work she will start pushing all the buttons. (car had been at dealer the day before and they shut everything off when its being worked on). Did my wifes button punching do something or is it only a matter of days before I go to no heat mode again?
Paul
North Vancouver,BC
Canuck1: Execellent DIY. My 211 E55 encountered the "no heat" issue Friday while driving to Whistler.
Paul
North Vancouver,BC
I believe it's very likely to happen again. It's only a matter of time because the valve fails mechanically. The teeth between the motor and the flap get stripped maybe. I never opened it up after I replaced it, but I definitely noticed a ticking sound like the sound of plastic teeth rubbing against each other after it failed.
Your wife did solve the problem, tho, even if just temporarily! At least that's what you should tell her :-)
Hi kurtwz,
Not sure if this is what I need to change. My problem is that the rea seats AC does not get cool air, only gets hot or room temperature air, while the front seaats AC works without a problem. Somewhere I rread that this is a problem from some dual valve situated under the front fender or mudguard. What is your opinion?
As mentioned it's much easier to just pull the wiper assembly which adds 2-3 min. to the entire job, but saves a lot of major effort.
I did Not read close enough and could have easily completed the job is less hen an hour, but was trying to twist out the outter hose connection. Not good as it's pinned and must come straight out, took me 20 min to figure that out.
On my CDI removing the engine cover creates a lot more room to access the outter connection.
Thx for the site & info.
1. remove brake unit (BOU), hardest part. Need to deactivate the SBC, remove accelerate pedal, brake pedal, flush brake fluid.
2. replace vale.
20 minutes removing vale,
few minutes cleaning up.
15 minutes putting new vale,
20 minutes replacing BOU (once you know how to remove, it's much easier to reverse.)
You will need WIS instructions.
It took me 3 hours to flush brake fluid. (First round failed.) Must follow every step carefully.
You will need DAS.
It's worthy. You will have your cooling back, also smooth and responsive braking.
There are two different heater control valves listed for the 2006 E320 CDI. One IS for cars WITH Auxiliary Heater (code 228) and one IS NOT for cars with Auxiliary Heater (code 228). Can anyone help me determine which part number I need? I do not know what the Aux Heater code 228 means or how to determine if it applies to my vehicle. VIN WDBUF26J66A955110.
211-832-05-84-M22 NOT for cars with Aux Heater (code 228)
211-832-06-84-M22 for cars with Aux Heater (code 228)
What is code 228?
What is code 228?
You could call a service advisor, they might help. It's a good thing to have your car's code list.
Code 228 is the electric aux heater. It warms the interior before there is sufficient heat in the heater core.
Now I'm going to double check the part I replaced. It did not solve the problem that I was having.
In my S320 I had a simular issue bit it was from side to side. (maybe the back / never sit back there) drivers side blew cool the passanger side blew hot no matter what it set the temp to. It was the Duo Valve - they get dirty or clogged. I bought a used one off line after googling it. It also can be rebuilt if your so inclined.
