iphone 3G with 08 E350
TIA.
I guess they consider it OK as the average is makes one for the average.
I'd suggest clearing your iPhone and then re-syncing with iTunes. Let us know if it happens again after the iPhone clearing and re-syncing.
-David
-David
Have you found why your addresses are doubled on the phone? Is it iTunes? Is it two Exchange accounts on your phone? Is it an exchange and MobileMe account?
Fix the doubling on the phone and I suspect you'll fix the problem with the car's Bluetooth.
Jose
http://mbclub.co.uk/forums/showpost....3&postcount=17
But the problem in this case is with the ViseeO device, the Euro MB HFP does not have this problem, it has a worse problem as it does not download the phone book at all.
Difficult to figure out but it looks like the current iPhone implementation confuses some of the car kits.
its not doubling the addresses you have listed.
Its listing all the phone numbers you have. It doesn't have a "submenu" for phone numbers.
John Smith - Home 361.555.1212
John Smith - Office 361.555.0001
It lists John Smith 2 times, because you have more than one number listed for John Smith.
Class dismissed.
Class dismissed.
On top of that, the delete function is highlighted on the command, press the button to delte the entry and the system says deleting and goes though its process and once completed the contact is not deleted.
Here is an exact way of what I did, I started fresh with a complete reset, synched the iphone for outlook contacts. Did not install mobileme and no other email accounts and synched again and every thing doubled on the screen and a side effect was that the phone entries on teh phone also doubled adn are saved into the iphone.
) but the different numbers only once the name is selected. Or are Comand phone books behaving differently, I'm referring to a W221. I've seen comments that the phone number type needs to follow those the MB system understands.
