E-Class (W211) 2003-2009
Passenger door lock pin problem...Help
Old Aug 7, 2008 | 02:25 PM
sef's Avatar
sef
e320
Question Passenger door lock pin problem...Help
Hi, I have a problem with my passenger side door. The lock door pin just goes up and down rapidly whenever i press the lock button or the unlock button. The car locks and unlocks fine and all the other door pins work correctly. Anyone know what the problem could be and any fix? Thanks.
The car is a 2004 e320.
Old Aug 7, 2008 | 02:31 PM
raymond g-'s Avatar
99 E320
check the door switch - plunger which is screwed into the door jamb. this is
a know weak point; mediocre design. you can try taping a dime just opposite
the switchn then closing the door to see if the pogo-ing subsides. if so, it
may indicate that the switch is needing to be replaced....or just needing
adjustment.
electrically speaking, the switch is designed to be normally closed, ie when the
door is open the swtich closes and power goes to the lights.
it should be a $20~ part
Old Aug 7, 2008 | 02:34 PM
Diesel Benz's Avatar
First results for "door lock" search:
https://mbworld.org/forums/showthrea...ight=door+lock
https://mbworld.org/forums/showpost....65&postcount=3
Old Aug 7, 2008 | 03:58 PM
tbone's Avatar
E500 Sport
I had that issue on the driver's side. Take it to your dealer. It was covered under warranty for me.
