Rusty Bolts on Brake Units
Regards,
paul...
The other parts are subject to extreme heat if the car is driven hard. It is difficult to protect the surface of different brake parts getting rusty. Stainless steel type of material may not be good by other properties.
Most of the parts are fine even after the surface gets rusty, only if rust prevents pads to move/work, the parts should be cleaned. Usually normal brake service is sufficient (worn out pads and discs replaced).
Good intentions are not free.
You are having a difficult time describing what you are talking about in writing.
Bolts that mount calipers to the wheel hub are indeed available separately.
Bolts that hold the halves of the caliper together indeed are not. Before anyone gets any ideas, I sure wouldn't try to replace these with something from Home Depot, as it's a given the specifications wouldn't match and these are important safety items. In fact it could be rebuilding of complete caliper could be required anytime the bolts are removed. Don't do it.
DTB S-B-42.10/109
MB position:
Corrosion protection coatings for brake components may be damaged and or stripped away if highly concentrated acid-based cleaners typically found in wheel cleaners are used ultimately causing hardware to corrode. Components damaged by cleaning solutions are not covered under warranty.
MB recommendation:
MB wheel cleaner for light alloy wheels part #001986347112 (for price comparison parts.com $11.50) environmentally safe to remove brake dust, oil deposits, road grime, spotting and prevent long-term tire discoloration.
Note: I couldn't get the thumbnail to post again here so here's the link to my 4-26-2009 posting "Brake Calper Painting Project": https://mbworld.org/forums/e-class-w...g-project.html
http://www.formymercedes.com/mb_resu...iper+Paint+Kit
I did blast and spray paint the steel carrier bracket.
The front ones are aluminum sandwitched around a steel (cast iron?) center so I blasted them along with those bolts and sprayed with a clear coat. Not sure how long it will hold up though.
Thanks for the suggestion. I'll prob go down this route. Not sure that will hold up but its got to be better than the rusty look i'm currently sporting.
