E-Class (W211) 2003-2009
Replacing W211 brake calipers.
Old Nov 22, 2008 | 11:39 PM
ap10046's Avatar
CLS500 M113
I have been scouring ebay for a while and there are loads of AMG 4, 6 and 8 pot calipers coming up regularly for the E/CLS 55's. They aren't too scarily priced either.
Would these fit a 2004 W211 E240?? I mean are the caliper mounting holes the same on the strut? Would they go on straight or would they require a carrier of sorts?? This, is of course, not taking the rotor size into consideration.
Old Nov 23, 2008 | 10:08 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
the front spindles have a larger bolt diameter for the AMG brakes (14mm instead of 12mm)
we have some (NEW) AMG brakes in stock as well btw
greetingz,
Attached Thumbnails Replacing W211 brake calipers.-dsc03070-640-x-480-.jpg   Replacing W211 brake calipers.-dsc03071-640-x-480-.jpg
Old Nov 23, 2008 | 04:14 PM
lkchris's Avatar
'10 CL550, '12 GL550
On might think this would require a master cylinder change as well.
Old Nov 23, 2008 | 05:34 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
The Brake upgrade on SBC W211s works Great Several have been done
as SBC cars have a Back Up master cylinder ...
Old Nov 23, 2008 | 11:39 PM
ap10046's Avatar
CLS500 M113
greetingz,
OOOOOOOHHHHHHHHHH!!!!!!!!!!!! THAT hurts!!!!!!!! LOL!! WOW..
Old Nov 23, 2008 | 11:46 PM
ap10046's Avatar
CLS500 M113
SO, may I assume they would fit the stock rotors straight (apart, of course, from the bolt diameter)?
Old Nov 24, 2008 | 01:46 AM
seahonu's Avatar
2015 GLK 250 BT
No, no. The rotors will be different. Std Eclass has 11.6" diameter rotors and AMG has 14.2" diameter rotors. So the change from std to AMG calipers would entail;
- new calipers
- new rotors
- new pads
- new pins
- possibly new carrier mount (between strut and caliper)
Old Nov 24, 2008 | 03:04 AM
ap10046's Avatar
CLS500 M113
- new calipers
- new rotors
- new pads
- new pins
The carriers are my biggest fear. I can machine the spindle bolt holes 2mm, no problems, but am afraid if the AMG calipers don't then bolt straight on?!
Rotors aren't an issue either.
Old Nov 24, 2008 | 05:29 AM
MBenzNL's Avatar
some slow@$$diesels
the E55/E63s use the exact same spindle as all other 211s - the ONE-AND-ONLY difference is that the caliper bolt holes are 2mm bigger...the 55/63 spindles don't even have more material around those holes - these are exactly the same except for the hole diameter (and thus - the calipers bolt straight on after enlarging those holes).
On my own E220CDI I had the original spindles machine drilled (watercooled)...as easy as can be.
greetingz,
Old Apr 17, 2020 | 10:47 PM
JohnnyGBenz's Avatar
2004 C230 Sport
Do you have slk55 Calipers for sale ? Thanks
Old Apr 20, 2020 | 11:50 PM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Arrow
Bumping a 12 year old thread...lol
smh.
-Nigel
Old Apr 26, 2020 | 12:20 AM
Goku801's Avatar
SL55
stoptech stainless steal brake lines on AMG calipers
smh.
-Nigel
Were you successful use the stoptech stainless steal brake lines? Did the part you bought from Amazon fit well? I am trying to get mine done, and the parts I received today have a tiny hole compared to the OEM line.
