E-Class (W211) 2003-2009
MB SA claims new RF trust arm is req'd as LF is being replaced???
Old Dec 2, 2008 | 05:50 PM
155's Avatar
155
R350
Exclamation MB SA claims new RF thrust arm is req'd as LF is being replaced???
I'd love your feedback on an issue i'm facing. A month ago I had too much fun with traction control off (in the rain) and ended up on a curb
The impact damaged my (driver side front) wheel beyond repair, bent suspension and caused an oil leak. Total estimated damage $5K CAD.
Fast forward one month and my car is at a local dealer for repairs. This is the email I received from my body shop:
Richmond MB says you need a LF strut and knuckle as part of the claim. I have to send a supplement to your insurance company for these items. The LF thrust arm was replaced as part of the claim but the new part superseded your old ones. Now you have to replace the right side at your cost or the alignment will be bad. They also looked into the oil leak and said the transmission pilot bushing is leaking. It is not accident related. I’m not sure what the cost is right now since I wasn’t the one that talked to [name]. I’m call you later when I know more.
A couple of questions:
1) Although an updated thrust arm could be redesigned I would assume it would keep the exisiting suspension geometry? Is it possible that both would need to be replaced? If so, should my insurance company not cover this?
2) My car did not leak one drip of oil before the accident. The day I brought it home (after the accident) it began to leak. Is it common for transmission pilot bushings to leak? Is it possible that this was a coincidence and I'm on the hook for this? Is it an expensive repair if out of my own pocket?
[edit: spelling, thanks lkchris]
Old Dec 2, 2008 | 06:24 PM
konigstiger's Avatar
'71 Pinto
If MB modifies a suspension part and stipulates replacing both sides for proper repair the insurance must cover the cost of total repair in accordance to the manufacturer’s specification.
Have the dealer check VMI to see if your vehicle is included in Service Campaign 2006020008 JAN07 – Inspect pilot bushing at electrohydraulic unit and replace if necessary. If so, it is a no cost repair even out of warranty as are any additional outstanding recalls and service campaigns.
Old Dec 2, 2008 | 06:35 PM
155's Avatar
155
R350
Konigster, I can't thank you enough. This board is unbelievable! Cheers,
Old Dec 2, 2008 | 06:46 PM
lkchris's Avatar
'10 CL550, '12 GL550
Don't know if it was the bodyshop or you that started the typo thing, but it's thrust arm.
Old Dec 2, 2008 | 07:58 PM
MB211's Avatar
2005 E500, 2011 ML350
You probably only need a new bushing. The new thrust arm (torque strut) was replaced with the new updated bushing. The arm should be the same. Should be $40 in parts and about an hour labor.
Old Dec 2, 2008 | 10:07 PM
155's Avatar
155
R350
Hey there,
Just to clarify. For the RF, I can re-use the existing thrust arm with the updated bushing? I assume than that the bushing can be sold seperately as opposed to the "kit" part?
Old Dec 3, 2008 | 12:09 PM
'71 Pinto
Originally Posted by 155
Hey there,
Part # in discussion is 2113331114 exchangeable in pairs only (see #105 in diagram) $37.50 list/30 net. The replacement solid rubber bushings have an increased resilience towards deforming. DTB P-B-33.15/16b AUG08 addresses this matter and stipulates do not replace torque strut assemblies only the bushings. If you want a copy PM your email address include your VIN if you want a MB datacard listing equipment and paint codes, initial delivery date, etc.
Attached Thumbnails MB SA claims new RF trust arm is req'd as LF is being replaced???-e320_front_axle.jpg
Old Dec 3, 2008 | 04:46 PM
MB211's Avatar
+1
As stated, only the bushing is needed. The only reason to replace arm would be if ball joint boot is torn.
Old Dec 3, 2008 | 08:45 PM
155's Avatar
155
R350
konigstiger/mb211 - thank you both for your replies!
