E-Class (W211) 2003-2009
Intermittent heater problem
Old Dec 9, 2008 | 10:52 AM
GFMBman's Avatar
2007 S550 4matic
My car started having problems with the heater few years ago. First, it will not produce as much heat as indicated by the temperature control - i.e., weak heating. Recently, the heater is having intermittent problem with the heater working or not working at all.
My heater will blow cold air (even at a maximum heat level) for days and then it will go back to proper working condition and this cycle of intermittent problem persists. Sometimes this intermittent problem occurs several times a day when I restart the car.
I read some of the earlier responses to a similar heating problem and it was suggested that I replace the heater control valve. I think it makes a lot of sense but will the defective heater control valve experience intermittent problems? I would think that once it is bad, it will stop working but obviously, I am not an expert here.. Thanks in advance for your help.
Old Dec 9, 2008 | 12:44 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
I would think that any value that has to open and close would operate intermittently (sp?) as opposed to completely "failing" in a open or shut fashion.I would look to having it replaced.
Old Dec 9, 2008 | 01:00 PM
GFMBman's Avatar
2007 S550 4matic
Thanks. Any ideas as to what might cause the heat control valves to go bad?
Old Dec 9, 2008 | 01:03 PM
C43AMG's Avatar
Veteran: Army
Might just be one of those things.I mean , you make a couple thousand of something you are bound to have a few failures.
Old Dec 9, 2008 | 01:13 PM
konigstiger's Avatar
'71 Pinto
Common failure part was modified, part #2118320584 $38.50 list/ 31 net.
DIY
https://mbworld.org/forums/e-class-w...rol-valve.html
Old Dec 9, 2008 | 01:49 PM
rcbrownjr's Avatar
2003 E320 Sedan
Similar situation with the intermittent heat, except that it has now gone inop.
Dealer wanted $350-500 to fix the problem. It looks like a managable DIY project, thanks for posting the instructions.
Where should I purchase the replacement valve? Through the dealer or are there better MB parts stores online?
Old Dec 9, 2008 | 02:18 PM
C43AMG's Avatar
Veteran: Army
Try here : http://www.autohausaz.com/
Old Dec 9, 2008 | 03:16 PM
'71 Pinto
$26.45
http://www.parts.com
Old Dec 9, 2008 | 05:33 PM
rcbrownjr's Avatar
2003 E320 Sedan
The changeover valve was out of stock at autohausaz.com. It was available at Parts.com. All-in price was as others have indicated, about $40. Sure beats $350-500.
Items Total: $26.45
Shipping: $10.99
Handling Fee: $2.00
Order Total: $39.44
Thanks for everyone's help. I will be sure to post how it all works out.
Old Dec 10, 2008 | 12:21 AM
tashakes's Avatar
2020 GLE350
I did mine, simple job, takes about 1 hr if you take your time and make sure you have all the tools you will need from the git-go.
Old Dec 12, 2008 | 04:29 PM
GFMBman's Avatar
2007 S550 4matic
OK, just ordered my part as well. Any ideas on how much they (local foreign car mechanics, not the dealer) might charge to install this?
Old Dec 18, 2008 | 10:17 PM
rcbrownjr's Avatar
2003 E320 Sedan
OK, part just arrived, but I noticed that it is not 211 832 05 84. Instead, it is 211 832 06 84. This part has what appears to be an extra duct coming off of it. (See pictures)
Has anyone tried the changeover valve replacement with this part? I have a 2003 E320 and am afraid that I will get into the compartment to find that I have 5 ports coming off the valve and only 4 hoses. I think that the part that was sent is for a later model E320.
Thoughts?
Attached Thumbnails Intermittent heater problem-e320-001.jpg   Intermittent heater problem-e320-002.jpg   Intermittent heater problem-e320-003.jpg
Old Jun 21, 2011 | 07:40 PM
capwormald's Avatar
E320
Thoughts?
Did you find out the fifth port is about??? I Have the same problem
Old Jun 21, 2011 | 09:26 PM
'71 Pinto
Thoughts?
2118320584 is correct part # for 320/500, 21218320684 is for 350/550
Old Jul 12, 2011 | 02:13 AM
spinn's Avatar
2004 E500
After replacing the heater valve on my 04 E500, I still am experiencing a heating problem. I get cool air through the vents, and have to adjust the temperature above 85 degrees (F) before I start to feel any heat, and even then, it's not gradual. I'm use to my other cars getting warm above 72 degrees, and could swear this was not an issue a month ago (only had car past 2 months).
Old Nov 10, 2015 | 12:42 PM
lez267's Avatar
E320
Hi spinn PLEASE FOLLOW UP WITH YOUR SOLUTION
«After replacing the heater valve on my 04 E500, I still am experiencing a heating problem. I get cool air through the vents, and have to adjust the temperature above 85 degrees (F) before I start to feel any heat, and even then, it's not gradual. I'm use to my other cars getting warm above 72 degrees, and could swear this was not an issue a month ago (only had car past 2 months)»
Same problem + This is not the valve, nor the small coolant pump, nor the heat radiator, nor the dash electronic display/control, nor the temperature sensors, nor some of the accessible actuators motors/flaps, nor the front SAM module. A very very costly problem and no result.
One last tought: «The key word is intermittent. Problem lies past the heating radiator since it would get very hot inside the car and very little air would go through it (4 actuator motors and flaps "failing" intermitently in unisson??' really!!) »
Old Nov 10, 2015 | 01:11 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
Can you explain as to why it is none of these??? You replaced all these things already>??
Old Nov 10, 2015 | 01:41 PM
lez267's Avatar
E320
Yes I did, except the improbable 4 stepper motors/flaps. It would have to be a common controller, connector or ground if they exist. I am looking for more detailed shematics or functionning principles.
Old Nov 10, 2015 | 02:08 PM
cmriv's Avatar
DAS/Xentry is what you need
Old Nov 20, 2024 | 06:54 PM
yando51's Avatar
2009 E350
lez267
I have the same problem. Did you ever fix yours?
Old Nov 20, 2024 | 06:55 PM
yando51's Avatar
2009 E350
lez267
