- Mercedes-Benz E-Class: Warning Lights
Important information to help you understand your Mercedes-Benz
Red battery message ( Visit workshop)
14-BS Battery replacment (12V 14Ah Sealed) Maintenance Free Battery.
That should translate into a: 14-BS 12v 14 Ah AGM sealed battery correct? Finding one seems a bit more difficult than I thought... you google that and similar batteries pop up but they all seem to be 12Ah rated. However, I went to BatterySharks web site and found a Sigma-Tek motorcycle battery Model YTX14AHL-BS. Its 12v, has 14 Ah rating, 210 CCA measures 5.28" long by 3.54" wide, and 6.54" tall, weighs 10.42 pounds. Haven't removed the cover yet so I can't compare the size. I remember the battery is motorcycle sized, I just don't know if its 100% compatible. Also I'm wondering if there's simply a need to clear the computer with a sequence of button pushes? Anyone have a clue?The AUX battery is your issue, I think. See below about that. 14-BS is just a size. Don't worry about AH. BS means "bottle supplied"; i.e. one that comes with the acid separately, because those are easier to ship. But the size is 14. Give me 5 minutes and I will have suggestions for you. I have a Die-Hard 14-BS Motorsports battery now in the car from Sears that I bought a while back, and a YUASA YTX-14BS before that. Both work great. Hang on and I will post a bunch of links. You DO NOT want a 14HL. Wrong size. You want a plain old 14.
DieHard from Advance Auto Parts: https://shop.advanceautoparts.com/p/...000%7CL3*15597 (Advance used to have an AUX14 battery that they sold specifically for Mercedes, and this is it in a new package.)
Advance also has what I'm confident is what I have in the car (having purchased it from Sears Auto Centers several years ago): https://shop.advanceautoparts.com/p/...archTerm=14-bs Their online indicator will say it doesn't fit your car, but that's just because ALL of the indicators will say it's for Motorcycles, because it is. This is a 14-BS AGM battery that you put the acid in yourself, and it will fit perfectly. I know because I have it.
YUASA YTX-14BS, which I had for years in the car, perhaps the best brand of powersports battery made [if authentic] through Amazon (but sadly not FROM Amazon anymore; they had a better price and you would know it's authentic):
VARTA (the OEM battery) from Pelican Parts: https://www.pelicanparts.com/More_In...=3868&DID=5038
Everstart from Walmart (if they have it locally): https://www.walmart.com/ip/EverStart...-14BS/16795217
Finally, since you're a Costco member and if you like Interstate, this one should work, I think. You might check the dimensions and which side the terminals are on compared to the YUASA [which I now did and, at least using the specs on the web site it looks fine], but I think this is just a TX-14 battery (no "BS" because they install the acid at the factory, like the AUX14 from Advance). https://www.costco.com/interstate-ba...100655022.html
You can usually work out a speedperks discount from Advance, although they have been resistant with the Die Hards. If you ask at the store and say you'd rather buy from them instead of ordering a YUASA from Amazon for $50 less, you'd be surprised at how cooperative and helpful they usually are.
NOTE: You want the 14-BS size, NOT the 14H-BS size. They're different.
These are decent prices on the major, reliable brands of batteries. Any 14-BS size should work, but you went out and bought your daughter a really good Interstate battery, so I know you want quality for her.
One tip: Advance will do a free battery check with the exact device that Mercedes says you have to use on an AGM battery to get a proper evaluation of whether it works (Midtronics tester). Advance actually told me my main battery was fine once when the light came on, and then I replaced the AUX battery and voila! -- light went off.
Another tip: The AUX battery only gets ten minutes of charge per start of the car, which was why my light would go off briefly when I did a bunch of driving stop and start around town, but then wouldn't go off after I drove one hour-long trip. So, because it doesn't get much charge from the car, be sure you fully-charge it at home before installing it (assuming you have a charger that has a nice low 2 amp or whatever charge to give the thing). Don't take any store's word that it's "fully charged" when they give it to you. It never is. Ask them to top it up and you'll come back later or tomorrow (but pay for it now).) If the main battery in there was as old as you think it was, then you got great life out of it and it would need replacing soon, but it probably didn't need replacing quite just yet. It's hard to believe that my car is 17 years old now, with 209,000 miles on it, because it still looks fantastic and runs great, but I got about 9 years out of my Die Hard Gold main battery, as much as the couple of times I had to go to the dealer they commented on how it wasn't the OEM battery. Yep. It isn't. And that's just fine with me.
AS TO THE BUTTON PUSH: I'm not really sure why the light goes out after you push a button after start. If I had to guess, because I had a similar thing where it would come on or off, is that it goes out shortly after starting because in the first 10 minutes of running, the Auxiliary battery is getting a charge from the alternator. After 10 minutes, it stops charging the aux battery (but not the main one, of course). And the cycle of the light coming on and then going off repeats. Before replacing it, if you want to try putting it on a charger (after disconnecting the leads) and seeing how that does, you could certainly try that before spending $70-120 on a new one. Or drive it over to Advance if you have one locally and have them test it. In my experience, they have the Midtronics tester and they're very honest about it and give you the printout if it has one, and/or do the test in front of you. At least where I am, they seem very-much dedicated to gaining customers for the long-haul, and telling someone they don't need a new battery is a good way to ensure that you'll come back to them when you actually do. Of course, it might be different where you are.
One final thought: Sometimes that red battery light means that the alternator isn't working. A quick-and-dirty way to test that is this: Go into the secret menu. To do this, insert ignition key, turn to the first detent (i.e. not the two clicks to fully on). If the temperature isn't showing in the main display, push the arrow buttons on the steering column until you're looking at the temperature. With the temp in the main display, push the odometer reset button (the thing that adjusts the brightness of the dashboard display) three times rapidly until the thing beeps. It will say UB: 12.1V (or whatever the voltage is). That's the voltage at the battery. Now start the car by turning the key the rest of the way to the right (don't turn it back first or you will have to restart this process). It will usually then show a voltage somewhere around 14 with the engine running and the alternator operating, but the exact number isn't important for our purposes. What's important is what happens if you rev the engine or start driving the car (you may have to clear the battery light by pushing the arrows again until the display comes back around to the UB: XX.XV display so you can watch the voltage). If it DROPS significantly when the engine is running or revving, then it may be an alternator issue; the engine is running off the battery rather than the electrical system, or, put another way, the alternator isn't putting out enough juice to run the car and it's drawing off the main battery. If your daughter was able to drive the car around with the light on previously and didn't get stuck somewhere, then this is probably not the issue, but it's an easy quick-and-dirty test.
I'm driving a 2004 E320 4Matic wagon, which is regularly serviced at excellent dealerships. In 20 years owning the car, I have not ever seen the "Visit Workshop!" red message, paired with a battery symbol, until today.
The car started up just fine, which seems to indicate no issue with the main battery. Today is Saturday; it was last driven on Thursday, no problems then. During the few minutes that it was on today, the engine was smooth; it did not sputter. (Given the error message I turned it off and scheduled service for Monday.)
The auxiliary battery was replaced in January, 2022 (I will ask the dealership on Monday to check the aux battery's relay.) The main battery was replaced January, 2020. The alternator was replaced in late 2019.
Just wondering if anyone thinks the earthquake yesterday - around 100 miles from where I am - might have caused an issue with the wiring? When the earthquake occurred, I certainly felt it. But nothing fell down (like paintings on the walls.) Only a door on an antique cabinet popped open.
It was suggested to me by a family member that maybe the earthquake shook something loose related to voltage, on the car. Just curious what those on this forum will reply about the "earthquake theory."
I came to this forum to try to figure out whether it would be safe to drive the car over to the dealership for service (located within 10 miles.) Apparently, assuming it starts again on Monday, I won't need to have it towed. Thank you for the background knowledge gained from skimming through the postings on this forum.
I am going to guess you have a battery drain while parked. Simply use a CTEK battery tander to workaround this issue.
Furthermore someone should scan your chassis to list was sick modules are "not sleeping" in low power mode. Replacing bad parts is the last step of a good repair once the issue are identified.
Water egress usually damages simple electricals connections os SAM Module in charge of the whole chassis power Mgt.
If you're not comfortable driving a questionable car ask dealer to arange for towing. Low voltage is best not to be trusted with your life.
Anyone have any idea how long for delivery?
I have done some research on a generic replacement. Today I went to a autozone and they had a direct fit/spec bat but it was acid version not the AGM. I tried to get the clerk but service as usual with young lady clerk
and young guy customer
.So for the record.
The factory part is mfg by FIAMM
They have at their website a direct replacement bat but the terminals are slightly different. Down side is not easily available in US.
The best change was for a
WESTCO 12B-4 in the AGM version. But you must have the square top post for both vertical and horizontal mount. Many will only have the horizontal post.
Second option is DELCO GTX 14-BS but no one local had this one.
Walmart has one the size ES12BS and but don't know if it is gell cell (agm) or lead acid.
Didn't have time to get to Walmart with all the returns going on today.
So I do believe there is a generic that will fit at a lower cost. But for the $total $115.74 delivered to the door with exact part number it was no longer economical to spend my time looking. Only down side is I have to wait for delvery and wanted to install it today. (Taking a 1000 mile trip next 10 days so hope the order arrives)
Interesting the procedure for installing the aux bat.
1) It requires disconnect main bat in trunk
2) Then replace aux.
3) Follow specific reconnect procedure for install main bat or possible damage to bat relay
So I was a bit suprised that the main bat can't just be reconnected after being disconnected. But then ocassionally I do learn something new. Happy New Year to all and be safe
. vettdvr
