E-Class (W211) 2003-2009
N95 and punk with tail
Old Dec 20, 2008 | 01:46 AM
mspaul's Avatar
2018 Macan, 2018 Panamera Turbo S E-Hybrid, 2024 G63
Has anyone tried pairing N95 (8GB US version) with the punk?
My blackberry works like a charm, but N95 does not even identify the punk as a bluetooth device.
any clue?
Old Dec 20, 2008 | 02:10 AM
Diesel Benz's Avatar
any clue?
Is that a branded phone or something? Did you activate the puck for pairing (not sure how the puck-with-tail works but my adapter needs to be activated from a button to start pairing).
Basic hands free should work to and from almost any device, certainly if it is a good N95 (no crippled operator version with limited features), it really should work in this case too. Things like the phone book availability may be a compatibility issue.
Perhaps someone with the same device will help you.
Old Dec 20, 2008 | 02:49 AM
mspaul's Avatar
Its original Nokia N95 V4 (North America version).
I tried pressing the button on the punk and then searching for bluetooth devices from my phone. It just says - No bluetooth devices found.
Forget about pairing, it does not even identify the punk.
I'll try again tomorrow...
Old Dec 20, 2008 | 05:56 AM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
any clue?
That's cause a punk is not a bluetooth device, it's just someone that's out to f*ck sh*t up . I'm sorry I couldn't resist.
Old Dec 20, 2008 | 06:14 AM
That sounds odd, does the phone find other BT devices? Perhaps its BT transceiver is broken?
Old Dec 20, 2008 | 12:23 PM
mspaul's Avatar
Yes, It does. I can pair n95 with my blackberry, laptop etc.
Old Dec 20, 2008 | 02:06 PM
jysong's Avatar
E320S4
I have an N95 and it pairs fine though the addresses do not get downloaded. My wife's Moto RAZR gets its addresses downloaded.
Old Dec 20, 2008 | 02:10 PM
mspaul's Avatar
Jysong, what firmware version are you running on your phone?
Old Dec 20, 2008 | 04:46 PM
mspaul's Avatar
Ok, pairing successful!
don't ask me how, I just deleted all the bluetooth devices on the phone and it worked.
Next to get the phone book to download. I was reading somewhere that upgrading to firmware 21.0.018 will solve this problem, but in order to upgrade the firmware for US N95, the phone will have to be flashed to change its product code and this can void n95s warranty.
WTF, I'm going to do it.
Will let you guys know.
Old Dec 21, 2008 | 04:08 AM
Odd that you had to that to get it paired.
There may be different tricks necessary to get the S60 Nokia device to download the address book. I'm not an expert at all but examples I've seen posted are:
- change the sync settings, edit the profile to use server version 1.1 for connection settings (I understand the security from 1.2 is not supported by the car system).
- install the phone book download manager intended for the Nokia 616 car kit.
Old Dec 21, 2008 | 10:03 PM
jysong's Avatar
E320S4
By default, my phone sync server version was 1.1 and the phone book does not download.
There is no download manager for the Bluetooth Puck with Tail to my knowledge.
Old Dec 21, 2008 | 10:15 PM
jysong's Avatar
E320S4
My firmware version is 20.2.005 which is the current version for the N95-4 (8GB US version) with the Nokia Updater Software. There is a 30.0.018 for the N95-2 (8GB Euro version).
Apparently, you can hack your phone to change the product code to trick the Nokia updater to think you have the Euro version and then install the 30.0.018 firmware. But I don't want to risk it because I know the Euro version does not support the US HSDPA frequency (3.5G) and don't want to risk losing that (and going back to EDGE for data). I can't confirm that will or will not happen, but again, I don't want to be the guinea pig.
