Just Smoked My Tail lights & Shaved
I brought my Tails into a car customization shop this week. They have a connection with a guy who does body work at a big New Car Dealership in town, he did a medium smoke and gloss. It cherry'd them out perfect. I think they look dope.
Barry, the only time I've heard that term, when applied to cars, was to door handles. Which is an aftermarket accessory kit enabling the door to open (not just unlock) remotely, with a touch of a button.
My question is how do you put them back on if you want to? There is a specific device (template) used at the factory to place them on the rear of the car. It is impossible to get the spacing/offset correct it you reapply them without that tool. Do any dealerships or bodyshops have that tool available that anyone knows of?
You can really tell that some cars have had bodywork by the missing VIN label and incorrectly spaced rear lettering on the trunk by just looking at pictures. Imagine trying to get KOMPRESSOR lined up and spaced appropriately.
I like smoked tails. That's obvious, since I did mine. Not a big fan of smoking the clear parts though. But it does look much better than stock. Now you just need to get the tips out from underneath the rear skirt. Do the cutouts or put a proper rear bumper on it and you're good to go.
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Same here, in regards to shaved. It has a door popper pop the door out a bit. Just have to make sure of the poundage you need for the popper, cause different doors weight different amounts. Also, you can install a linear actuator to open the door all the way while holding a button down. SPAL makes the best linear actuators. They're good, the guy is Italian, know him myself.
