E-Class (W211) 2003-2009
re: hk speakers
Old Jan 5, 2009 | 02:08 AM
Dtv211's Avatar
E320
re: hk speakers
Ok. I've done an extensive search on how to remove & replace the right passenger side hk speaker, because I tried doing it myself, and I have an extremely hard time trying to get the speaker to come loose after unscrewing the 4 screws.
My question is, does anyone know if it is glued down? I remember reading a post from someone (can't recall his/her name) re-doing his/her audio system and had mentioned something about these speakers by the footwell being glued down, or something like that.
Any information would be most appreciated.
Thanks, and Happy New Years!
Old Jan 7, 2009 | 04:15 PM
starbrite's Avatar
2004 E320
Would help if you told us year and model.
Old Jan 7, 2009 | 04:53 PM
Clinton Horn's Avatar
2003 E320
I have a 2003 and the door speaker is firmly attached. It has 4 screws but they don't release it. My car was a lease return and someone removed / stole the tweeter from the door pillar. The replacement I found had a harness with it and fortunately, I could reattach it without removing the door speaker so I never solved the puzzel. I would say they are attached with adhesive. They definitely do not release with moderate tugging.
Old Jan 7, 2009 | 05:12 PM
starbrite's Avatar
2004 E320
Possibly a double sided adhesive ring. A bit of heat from a hair dryer maybe enough to break it loose AND preserve the adhesive.
Old Jan 7, 2009 | 05:28 PM
konigstiger's Avatar
'71 Pinto
The speakers do have adhesive (butyl sealing cord #5) also attached to door foil #1. I apologize for the images but you get the idea.
Sealing cord part #005989127110
Cleaner 0059891971
Attached Thumbnails re: hk speakers-spk_adhesive0001.jpg   re: hk speakers-spk_adhesive0002.jpg
Old Jan 8, 2009 | 08:07 AM
2003 E320
I believe butyl caulk is used to set glass in most vehicles. I also believe that wrecking yards use piano wire to cut windshields out for salvage. Butyl caulk just gets tackier with heat. Wire might be a reasonable option.
