E-Class (W211) 2003-2009
What the hell is going on with my tranny?
Old Jan 19, 2009 | 10:52 PM
shadinator's Avatar
2006 E350
Originally Posted by mcleantmw
These are the years and model vehicles listed from the MB TSB that have the Valeo OEM radiator installed. If your car is one listed, it has the Valeo radiator unless it was replaced by a prior owner. My advice is to do preventive maintenance and replace the radiator with the new version. Can't be that expensive and maybe your MB Dealer might be able to get MBUSA to pay for it if you cite the TSB. To preclude OEM radiator failure, I've seen a few posts on this forum that some MB owners have installed a new, separate transmission cooler system to bypass the OEM radiator.....but why do that when it's easier to just replace the radiator. PM me if you want a copy of the MB TSB.
I checked the codes that you listed and it looks like my VIN falls in the ones that has the valeo radiatory. I will pm you my VIN number to confirm with you. If you dont mind emailing me the MB TSB I would greatly appreciate it. I will also pm you my email address. I will probably check with the dealer and see if it can be replaced even though I am well out of warranty (74k miles now). Have other people successfully gotten their radiators replaced even though they are out of warranty? Once I get the TSB I will see what can be done. If the dealer refuses, I will probably get a glycol test and get my radiator replaced elsewhere.
My car definitely has the low humming/buzzing/drone noise that you mentioned at low rpms (is louder when the air or AC is on) but we have had that problem since we got the car. We even had a couple of the service techs come out with us in the car and they always told us it was normal. Our 2006 E350 is dead silent at low rpms, you cant even tell the engine is on... thanks for your help!
Old Jan 20, 2009 | 01:23 AM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Just got my car back today. They replaced the entire transmission, radiator, cooling lines, and torque converter. I was lucky that I had CPO, it covered it all.
Old Jan 20, 2009 | 07:42 PM
Clinton Horn's Avatar
2003 E320
Valeo Radiator
I found this post from another member. One picture / thousand words.
The Valeo radiator has dental type crimping. Very distinctive and different from Behr. My E320 falls under the 065 chasis number mentioned above but it has a Behr unit. Possibly replaced in during the lease.
See posts 1 and 13
https://mbworld.org/forums/c-class-w...placement.html
Old Jan 21, 2009 | 02:02 AM
gaazmon's Avatar
See posts 1 and 13
Very good diy post. I've heard this to also be a persistent problem on the C32s as well.
Old Jan 23, 2009 | 07:02 PM
leehowell7's Avatar
MB E500
MB will pay for the parts if you bring up the TSB!
Hi 6HIFER,
My out-of-warranty 2003 E500 with 48K miles started with the shuddering last week. After reading all the posts, I knew it was the faulty radiator leaking into the transmission. Sure enough, my SA called and said I had a postive glycol test and needed a new radiator and recommended a new torque converter. I agreed to both. Once the work was done, I brought up the TSB, suggested MB cover the costs due to the obvious design flaw. He agreed to covering the parts ($2K), but I paid the labor ($1.5K). Hopefully, no more trouble!
Old Jan 23, 2009 | 09:08 PM
e55 baller's Avatar
W221 S65 AMG
Hey guys, i just saw this post and we are talking about these problems in the W211 E55 part of the forum.
Does the symptom of this issue seem to be like that described in this post?
https://mbworld.org/forums/w211-amg/...eleration.html
Old Jan 27, 2009 | 12:10 AM
  #32
tashakes's Avatar
2020 GLE350
Well, crap, I finally determined that I have a Valeo because of the crimping. I will be sending a sample of the trans fluid for testing, hopefully it will come back negative.
I will be doing this every six months from now on, I should be able to catch any problem within these periods. I have decided not to replace the radiator until I know that there is a problem. Knowing me, now that it is on the back of my mind, I will probably just replace the darn thing within the next few months anyway, seems like a simple enough job.
Is there a way to know how many failures there have been vs how many cars came with these radiators? From what I see, the percentage should be on the single digits, but I may be completely wrong.
Old Jan 27, 2009 | 01:20 AM
  #33
dvmak's Avatar
'06 E500 Flint Grey - Charcoal
Why even take the chance? If you wait until it compromises the tranny .. even if caught very soon .. it may cause some damage.
Old Jan 27, 2009 | 06:29 PM
  #34
mcleantmw's Avatar
2003 E500 Benz & 2015 BMW M235ix
I agree..........replace the Valeo now with the updated part no. version.........when you start noticing the problem, your torque converter and maybe trans could be toast! You'll also have to flush both systems completely when it fails.
Old Jan 27, 2009 | 07:16 PM
  #35
ECLASS500SPORT's Avatar
BENZE500
I have an 03- E500 with 60K miles. I had noticed the jerking and did the inspection of the radiator and did find that I had the Valeo ,my SA said no contamination was found.
I replaced the radiator and had the trans fluid changed. I do still have the jerkingthough when I am in Sport mode.
Is that expected with our tranny? I dont assume it should get any worse seeing Ive taken the proper steps to prevent damage.
Old Jan 27, 2009 | 08:10 PM
  #36
konigstiger's Avatar
'71 Pinto
I replaced the radiator and had the trans fluid changed. I do still have the jerkingthough when I am in Sport mode. Is that expected with our tranny? I dont assume it should get any worse seeing Ive taken the proper steps to prevent damage.
DTB P-B-27.20/78 may be the torque converter.
Old Jan 27, 2009 | 08:14 PM
  #37
BENZE500
would it be from glycol contamination. Please email me the DTB. Thanks
Old Jan 27, 2009 | 08:58 PM
  #38
tashakes's Avatar
2020 GLE350
True that, just waiting to get a break from expenses, I dont have to pay my kid's college tuition during the summer, so I wanted to do it then. For now I will send oil to test and hope for the best. I will start getting quotes on radiators, looks like I can do the job myself.
Old Feb 4, 2009 | 08:57 PM
  #39
rsatmans's Avatar
None
Hey Guys,
I have a leak at the conductor plate on 2003 clk500. They said I shouldn't just get the plug as it would probably fail in a couple of months but instead get the whole new plate. About $700 including labor, does this sound correct? I also see that my car has a valeo radiato and it is in those years of the TSB can you please send me a copy. I am going to have the dealer check for glycol.
Old Feb 4, 2009 | 09:02 PM
  #40
mcleantmw's Avatar
Originally Posted by rsatmans
Hey Guys,
Send me a PM with your email address and I'll be happy to email you the TSB.
Old Feb 5, 2009 | 08:10 PM
  #41
rsatmans's Avatar
None
Thank You So Much! I will report back after I talk to dealer.
Old Feb 6, 2009 | 01:02 AM
  #42
SZMB's Avatar
2004 E500 CLK320
How does the coolant from a leaky radiator gets into the transmission? If the radiator leaks, shouldn't the coolant level running low and we should be able to see coolant in the engine compartment, and fix the leak before resulting in permanent damage to the tranny?
Old Feb 6, 2009 | 11:36 AM
  #43
Air Marshall Eldritch's Avatar
John Deere
Hey Guys,
No, that sounds too high, although it might be typical for your dealer. I had my conductor plate changed along with the last fluid/filter change for under $400 all in from a MB-specialist indy.
Old Feb 9, 2009 | 08:36 AM
  #44
mcleantmw's Avatar
It's an integrated radiator for both the engine cooling and transmission systems. There's a transmission line with a connector that breaks and allows coolant to enter the transmission line thus contaminating the trans fluid and damaging the transmission and/or torque converter. In my case, they only had to replace the radiator with the upgraded P/N and the torque converter..........transmission didn't suffer any serious damage. All was covered under my CPO warranty.
Old Feb 12, 2009 | 12:44 AM
  #45
trevorc21's Avatar
2007 E350
Exclamation 2007 E350 tranny prob
Anyone heard or had same problems as these previous posts other than these prev 03 models? My 2007 E350 has had some problems since I bought it July 06. Dealer has always denied problem. Car is completely stuck in first gear now. Anyone have extra insight? Car is not under warrany, any "easy" repairs to get it out of first?
Thanks so much!
Old Feb 13, 2009 | 01:23 AM
  #46
Untertürkheim's Avatar
Thanks so much!
Have you inquired about buying an extended warranty?
Old Feb 13, 2009 | 07:15 PM
  #47
trevorc21's Avatar
2007 E350
it's broke
Ummm, after it's already broke????
Old Apr 18, 2009 | 01:55 AM
  #48
SoCalCLK's Avatar
2017 W205 C43 AMG
If the gears are stuck it may be the worst. 1) check for glycol contamination 2) a new radiator must be installed either way 3) a new torque convertor may be needed depending on how much glycol contamination there was. 4) at least you will have a fresh tranny and radiator going forward
Old May 27, 2009 | 04:12 AM
  #49
tarokyama's Avatar
2004 CLK500 COUPE/AUTO
I have a 2004 CLK500 with a VALEO radiator installed
however the manufacturing date of my Vehicle (as noted by the sticker
inside the door) is 01/04 Does this mean my Valeo radiator is OK??
or should I change it out?
please advise!!
thank you
Old May 27, 2009 | 12:17 PM
  #50
SoCalCLK's Avatar
2017 W205 C43 AMG
please advise!!
thank you
How many miles do you have on your car? If everything is fine, you could live dangerously and do nothing. But the way I see it, you have to choices:
1) Replace the Radiator ONLY right now. $
2) Replace the Radiator AND Torque Convertor later (which is that I had to do). $$$
