CDI owners - C or S mode?
If you kick down, it should not matter if you are on S or C except that the car needs to change first from the second to the first gear (if the speed is low enough for the first gear).
I did not find the W211 power curve but from the attached W221 figure you can see how the car should change gears. Taking a typical gear ratio of 1.4 between consecutive gears, the car should rev up to some 4200 rpm where it would go down to 3000 rpm with the next gear. You can see at 3000 you would get the same power as at 4200, the average power being maximised with that gear throughout the used rpm range.
On the 7G-tronic the car starts with second gear on C and changes up at lower revs on C.
I may remember wrong but at least my W211 5-speed starts with first gear, not sure if all models do. In any case it would change up at lower revs on C. This may not be easy to notice though.
S stands for Sport mode. From a stand still the car starts from 1st gear forward and reverse. The transmission is mapped to shift after 3,000 rpm and is more on the reluctant side to shift up maintaining higher rpms to produce more torque.
According to the manual during the break in period the car should be in C mode until it settles in and the revs should not exceed 2/3 of the engine rev band.
I drive my car in C mode because I sit in bumper to bumper traffic every morning and the acceleration is much smoother in C mode because it starts from 2nd gear. On a side note I also noticed that breaking is also affected by which mode the car is in. In S mode I have more dead play on the break and then suddenly the breaks bite. In C mode there is no dead play on the break and the break bite feels more uniform.
Cheers
Bryan
Cheers
If you use kick down, the car would anyway change to first gear and the only difference between C and S is that there is some delay from the shift.
It is pretty difficult to figure out which gear is on while accelerating at full power. It all happens so fast anyway.
Toronto is so cold and icy it makes sense to use C now. In San Francisco it makes little difference apart from fuel economy.
http://www.youtube.com/watch?v=oTsN2eK0MQs
Do we know for a fact that the 7speed tranny combined with the bluetec is supposed to start off in second? I know the 5speed cgi is supposed to, but I can't find definitive info on the 7 speed, bluetec combo. Any help is appreciated.
Regard,
Bryan
Regard,
Bryan
