E-Class (W211) 2003-2009
Balt joint support
Old Jan 21, 2009 | 06:29 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Balt joint support
Hi guys,
Anybody experience squizing noise that comes from the suspension area.
The tech told me its the the botton balt joint support.... that this car has 2 balt joint, one in the top and one in the botton.... in order to make the squizy noise away, i have to replace the balt joint support that cost about $700 ...... anybody experience this before ? according to him, its a commom problem.... same for the S class......
Anybody has this experience pls let me know.....
Thanx
Old Jan 21, 2009 | 07:04 PM
Benz-O-Rama's Avatar
Originally Posted by CharlyE500
Hi guys,
Thanx
Yep, very common on our cars. Search the forum and you'll find more than enough reading on the subject.
Old Jan 21, 2009 | 07:54 PM
MBNUT1's Avatar
2010 E350 4Matic
When you do you search use ball joint not balt joint
Old Jan 21, 2009 | 08:25 PM
CharlyE500's Avatar
Oh..... Thanx.....
Old Jan 22, 2009 | 09:11 AM
vettdvr's Avatar
03 E500 and Corvette
Hi guys,
Thanx
Yes the BALL joint fails IMO prematurely given the purchase cost of this vehicle.
Old Jan 22, 2009 | 04:57 PM
CharlyE500's Avatar
One more thing, is it safe to drive without fixing it ?
Old Jan 23, 2009 | 01:09 AM
Diesel Benz's Avatar
In practise it is safe if it has just started producing noise, likely safe even quite a while after that but not for ever. And you would lose tyres from incorrect alignment etc. So better to fix it one you find a joint that isn't tight or makes noise. Most MB joints can be replaced separately from the arms and aren't even that expensive.
