E-Class (W211) 2003-2009
Onboard Bluetooth
Old Jan 24, 2009 | 09:47 AM
JCFans's Avatar
2005 E320
Onboard Bluetooth
I have a 2005 E320 that didn't come with the on-board Bluetooth that you can use for the telephone function.
Does anyone know how can I manually install this without going to the dealer?
Just curious.
Old Jan 24, 2009 | 11:39 AM
KYBENZ's Avatar
2011 E350 4 Matic,1994 C220,1965 Mustang, 2005 Kawasaki Vulcan 1600
First you need to determine if the car actually has a phone installed in it.
Do you currently have a cradle or plug in the console area?
If so it is just a matter of plugging in the BT puck and linking your phone.
Old Jan 24, 2009 | 03:44 PM
JCFans's Avatar
2005 E320
When I clicked on TEL, it says "no phone is installed".
Old Jan 24, 2009 | 11:49 PM
dieselsrule's Avatar
2005 E320 CDI, 2009 SLK350 (wife's toy), 2007 ML320 CDI,2001 dodge 1 ton diesel
incartronics.com has a bluetooth adapter that is supposed to plug into a command system and not need any dealer programming. I also have an 05 E320, and the bluetooth is the next mod for it. I have already installed factory Nav and sirius system.
Old Jan 24, 2009 | 11:56 PM
mmartinez's Avatar
2004 e320
I also had the "no phone installed", I purchased the itronic unit and no I can use all my factory phone buttons
Old Jan 25, 2009 | 01:01 AM
JCFans's Avatar
2005 E320
Thanks, dieselrule!
mmartinez, did you purchase this from the incartronics.com?
Old Jan 25, 2009 | 01:27 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Do you have a phone connector in the center console? If so, you can purchase a Bluetooth puck and install it and that's all you need. There's usually always one for sale in the classified section.
Old Jan 25, 2009 | 01:55 AM
Polar Bear's Avatar
If you don't have the connector (as it sounds like you don't as you would get an "Insert Phone" or similar message) the link posted above looks like it would be a much easier solution to implement since you will not have to install the equipment in the trunk. I am not familiar with the performance of that product however.
Old Jan 27, 2009 | 11:05 AM
JCFans's Avatar
2005 E320
Do we have a cheaper alternative to the incartronics.com?
Old Jan 27, 2009 | 01:22 PM
JCFans's Avatar
2005 E320
Also, how can I check if I have an in-dash microphone built-in? Even incartronics.com would not work if I didn't have a mic right?
Old Jan 27, 2009 | 02:41 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i still have GB going on for mObridge BT kit....
check GB section...
Old Jan 27, 2009 | 11:43 PM
Polar Bear's Avatar
OEM parts would cost more than that system.
All US 211s should have mics as it comes with Tele-Aid. They're either on the top or bottom of the rear view mirror.
Old Jan 28, 2009 | 10:35 AM
JCFans's Avatar
2005 E320
What is the GB section? Sorry I'm new to this forum.
Are you selling one?
check GB section...
JCFans's Avatar
2005 E320
Thanks, Polar Bear!
Old Jan 29, 2009 | 10:06 PM
MB_E500's Avatar
2006 E500
For $950 you can buy a brand new Mercedes Benz MHI control box, MOST cable, Puck, ect from a dealer in CA. I just bought this, plus another $400 for the Voice Control System. Its about a 45-60 min job for guys with basic mechancial skill, it just plugs anplay with the built-in electronics rack in the rear. No need to wire an ugly non-oem mic either. You will need to have the car updated "Version Flashed" to use the steering wheel controls but head-in unit of COMAND will work fine. I have the latest Mercedes Service Bulliten to perform this install. Its 6MB, so email me and I will send it to you or if you want the dealer name and number. Thanks!!! Scott.
PS: Rolling in a 2006 E500 with Sport Package, NAV, SAT, VCS, BT, HID Active lighting, HK Sound, AMG rear spoiler, Keyless go, birdseye maple, parktronic, side and rear power sunshades and power trunk. Just added T10 LEDs after being tired of the dull yellow parking lights. Check out my posts for more info, but it was only a 25 min job!
Old Jan 31, 2009 | 04:08 PM
Chicago_Buckeye's Avatar
560SL, E500
No need to spend $1,350 to get Bluetooth in your car. Can be done for $365 with the OEM "Puck with Tail". Check the MBWorld thread "Puck with tail" initial impressions. This approach won't give you the Voice Control System, but I'm sure the $1,000 you'll save will help you live without it and dial numbers yourself .
The Puck with Tail is the ONLY thing you need to buy/install (which you can do yourself in less than 15 minutes). It uses the microphone and speakers installed in every W211 for the TeleAid - which is why you then need to have your dealer version code your Benz and have TeleAid "recognize" there's a phone installed. By the way, you DON'T need the upgrade to digital TeleAid either (in case your vehicle doesn't have it).
Once you get this done, EVERYTHING works - steering wheel controls for Telephone System, auto mute when dialing/receiving calls, caller ID for incoming calls on dashboard and COMAND. Hope this helps, let me know if you have any further questions.
Old Jan 31, 2009 | 06:43 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Puck with tail doesn't work on cars 05 and above, if I remember correctly.
Old Jan 31, 2009 | 11:45 PM
Polar Bear's Avatar
As others said - only works with 2003 and 2004 cars.
Old Feb 8, 2009 | 11:04 PM
560SL, E500
I stand corrected
Too bad it won't work on 05 and later; SUCKS to have to spend all that extra money when the Puck with Tail does it for so little.
Old Feb 9, 2009 | 01:47 AM
Polar Bear's Avatar
I stand corrected
Indeed it does. And the installation is much more involved unless you are prewired for MHI.
Old Feb 9, 2009 | 03:57 AM
gaazmon's Avatar
I stand corrected
Ya, the puck with tail thing was a lot easier. I guess MB wanted to make more money off of us. They really started to f*ck up in 05, with this decontenting bs.
