E-Class (W211) 2003-2009
iPod volume, etc.
Old Feb 24, 2009 | 10:21 AM
konigstiger's Avatar
'71 Pinto
Arrow iPod volume, etc.
DTB S-B-82.85/544a FEB09
ML as of MY06, SLK MY05-08, C MY05-07, CLK MY05-08, E MY04-08, CLS MY06-08, and R as of MY06 with iPod interface kit
iPod intermittently cannot be operated or controlled using steering wheel controls, delayed response on IC display, and/or iPod volume too low compared to other audio sources this may be due to incorrectly loaded MP3 files onto the iPod, the Aux level of the iPod is too low, or a CAN communication error between the head unit and the IC. To resolve, the iPod Interface Module should be replaced with part #B67824252 or later.
FYI if equipped with the latest iPod interface, you can adjust use this procedure to adjust the Aux volume output:
- Use the MFD buttons to select the iPod menu (Aux) in the IC
- Simultaneously hold down the down arrow + Tel hang-up MFS buttons for about 8 seconds the IC displays “DIAG”, “HW” -> wait another 5 seconds -> “DIAG” “Vol…”
- Within 5 seconds of the “DIAG”, “VOL” display appearing, pres the up or down arrow to adjust the Aux volume. Make sure it is set to the loudest -> wait 5 seconds without pressing any buttons -> the display will return to iPod main screen automatically.
Old Feb 24, 2009 | 09:33 PM
pinebaron's Avatar
07 E320 Bluetec
You may additionally install an IPOD preamp, an item available from MB; it connects between IPOD and the original connector wire to Command. It is plug in with no splicing required.
Old Mar 6, 2009 | 03:44 PM
tivoboy's Avatar
2016 C450 AMG, 2009 C300, 2001 C320 2001 CLK430, 95 E500
Is this adjustment listed above the best way to up the volume on the AUX/ipod in? i have just been trying the ipod connector in the new C300, but indeed the volume is a bit low and always has to be adjusted up.
Old Mar 6, 2009 | 08:56 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
I have had mixed results in the amplifier. At first, I could tell a big difference in sound quality (it was much better) however after listening to many more songs, I noticed it introduces distortion/clipping depending on the max level the song is recorded.
I have normalized my library to a lower level to attempt to compensate, but it still seems to clip, which will damage speakers.
I am curious if the COMAND is causing the clipping, or of it's the iPod interface itself.
Old Mar 7, 2009 | 07:13 AM
pinebaron's Avatar
07 E320 Bluetec
iPod quality cannot be compared to CD quality however clipping or distortion can be minimized by reducing input as described in post #1. I rarely use it at full blast hence cannot comment on damage to speakers. In recent years, MB have reduced Bass pre-amp output in Command to protect speakers. I have considered installing aftermarket speakers but have not got around to the task yet.
Old Mar 7, 2009 | 07:33 AM
Polar Bear's Avatar
My particular iPod adapter is the older software version without that feature.
As for the distortion/clipping damaging speakers - you do not have to listen at a high volume for it to damage speakers. If they are receiving a distorted signal (even a low to moderate volume) the signal is not clean and therefore can promote speaker damage.
I think it would be difficult to replace the speakers if you have an H/K system due to impedance matching, etc.
Old Mar 7, 2009 | 07:45 AM
pinebaron's Avatar
07 E320 Bluetec
An interesting article for your reading:
http://www.monstercable.com/mpc/stab...Some_Facts.pdf
Old Mar 7, 2009 | 07:56 AM
Polar Bear's Avatar
Hmm - according to Richard (a very nice guy in the Grand National community and he actually hosted a meeting at his garage recently) it would not damage the speakers if it is clipping before amplification.
Good read!
Old Mar 7, 2009 | 08:02 AM
Polar Bear's Avatar
That post actually makes me feel a whole lot better because now I won't be as concerned that it will cause speaker damage... that keeps me from listening to my iPod as much.
I always knew that a stronger amp would minimize speaker damage over a weaker one causing distortion, but this obviously only applies if the amplifier itself is causing the distortion.
Old Mar 7, 2009 | 02:08 PM
pinebaron's Avatar
07 E320 Bluetec
I worked as an audio test engineer for a Japanese Mfg. for several years. I took the easy way out by sending you a link.
Old Mar 7, 2009 | 04:10 PM
Polar Bear's Avatar
Thanks for the good info - I worked in the auto sound industry for a while and apparently that is a fairly common misconception. Glad to get the right answer to that question!
Old Mar 21, 2009 | 10:35 AM
Polar Bear's Avatar
I wanted to add some info to those who may be following this thread - and for the sake of future searches...
I had the DTB performed and had the outdated iPod adapter replaced with a current version. The distortion I was experiencing disappeared. It appears that the old iPod adapter was being overdriven by the iPod, instead of the AUX input on the COMAND unit being overdriven by the iPod module/amp.
A few experiences support this idea that I performed *before* changing the module -
I re-encoded my music on my iPod to a higher dB (target 98dB) to compensate for the lower volume issue that many experience *without the in-line amp* and still experienced the distortion.
I then lowered the volume of the music on the iPod to a lower dB (target 89dB) and reinstalled the in-line amp. I experienced nearly the same volume as the method listed above, and still experienced the distortion.
After the new iPod module was installed as listed in the DTB, the in-line amp was actually still in the car, and there were no distortion even with the amp installed and the iPod module configured for VOL: +++ setting.
So... it sounds like the old iPod adapter clips at a lower volume/input level than the newer one.
Old Mar 21, 2009 | 04:22 PM
mprsev's Avatar
2024 G63, 2021 X7M50i
Thanks for the follow up post. How can I determine which version iPod adaptor I currently have? I am running the $0.05 in-line amplifier and the sound definitely distorts now even with my iPod at half 50% volume, Flat EQ and Sound Check On, and iPod module configured for VOL: --- setting.
Old Mar 21, 2009 | 08:53 PM
Polar Bear's Avatar
To get the hardware and software version:
With the key on and the iPod playing and the menu displayed in the I/C press the ↓ button on the steering wheel, with the Telephone Hang-Up button at the exact same time (the post above states the ↑ button, but this did not seem to work on mine for some reason). Hold it for about 7-10 seconds and the display will display the hardware information and software version. Mine displayed HW2006 E41 and SW1706 100. This is before the VOL:--- is displayed.
With the updated iPod integration unit, the in-line amp is not needed (nor recommended from what I have read). Also, I haven't seen where the volume on the iPod actually makes a difference as I think it uses a "line-out" function on the iPod. I use an application called iVolume to normalize the iTunes library, and turn Sound Check on on the iPod and disable the EQ and get pretty good results now.
Old Mar 22, 2009 | 01:39 PM
Polar Bear's Avatar
If you would be interested in trying a test track, send me a PM and I will provide a download link. The track in question always distorted on my previous iPod module, but no longer does on the new one. It is a track from the Robert Plant and Alison Krauss CD Raising Sand.
I now get zero distortion with the new model - at least with the tracks I have played so far - so it was apparently the iPod module the entire time, and not the AUX input on the COMAND.
Old Mar 24, 2009 | 01:37 AM
mprsev's Avatar
Thanks Polar Bear! I checked and my dash displays HW2006 E41 and SW1706 100 as well so I guess I have the latest? So I guess I need to remove the inline amplifier.
Old Mar 24, 2009 | 02:05 AM
Polar Bear's Avatar
I would try that and see what it does.
I am enjoying my iPod 200% more than I used to with the old module!
Old May 11, 2009 | 11:12 PM
Dtv211's Avatar
E320
Maybe this is a dumb question, but does this apply to ipods only, or for all audio aux inputs? I tried to play my 300 mb Paul Van Dyke mix on a blackberry storm today, and it sounded really low, bummer
Old May 28, 2009 | 04:44 PM
t-bone's Avatar
2004 E55
Was it free to have the module replaced?
Old Feb 25, 2011 | 09:31 AM
hercules's Avatar
W203 C200K-2003
I have all the symptoms that you describe above with an ipod iterface I purchased on Ebay, I can not remenber What part number is , but lately I have puschased at a good price a new interface B6 7824252 from a dealer in Germany and for lack of time I have not had the opportunity to fit it yet .
Do you think this should solve all the problems you decribe.
By the way it is for a W164
Old Feb 25, 2011 | 10:33 AM
'71 Pinto
Originally Posted by hercules
Do you think this should solve all the problems you decribe. By the way it is for a W164
It should this is why MB released bulletin to address symptoms listed -- ML (164.175/186/871) as of '06
