E-Class (W211) 2003-2009
DIY rattle fixes?
Old Feb 25, 2009 | 11:58 AM
BlackFox's Avatar
DIY rattle fixes?
My W211 is seriously working on my nerves with just 2 rattles.
One is coming from somewhere beneath the dashboard (I think from below the a/c unit) and rattles a lot on bad roads (and we have a lot of those here in Belgium) and also when the throttle is past 1/2 in low rpm's.
Being a 4 cyl diesel, it vibrates a lot more offcourse, but that still doesn't mean it should rattle this much.
The other seems to be coming from the panoramic roof, like there's something loose in the light unit. But I'm not sure about that actually.
The dealer has only tried to fix these rattles for about a million times, but they're not very good at it.
In fact, it seems like they didn't even try.
I'm fed up with it and wanted to try it myself, but I don't have an idea where/how to start.
I allready tried to dissassemble the dashboard, but I can't remove the A/C unit because the wood trim needs to be removed too, to be able to reach the screws for the audio unit ?
I also tried to remove the wood, but it only slides an inch or so to the right and then it's totally stuck.
I hope you guys can help me with pictures, a detailed explanation or some exploded views because it's driving me nuts...
Old Feb 25, 2009 | 12:09 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
You do not need to remove the wood to remove the audio unit - only the storage compartment/CD Changer, ashtray, and shifter surround.
Old Feb 25, 2009 | 12:18 PM
BlackFox's Avatar
According to an exploded view schematics, there should be 2 screws that hold the A/C unit in place, behind the wood strip?
Anyway, now I need to know how to remove those other things
Old Feb 25, 2009 | 12:55 PM
konigstiger's Avatar
'71 Pinto
PM your email address.
Old Feb 26, 2009 | 09:04 AM
vettdvr's Avatar
03 E500 and Corvette
Mine has a high frequency whine at very low db's when cruising a/c off windows up and sun roof open. The whine is from the engine or acc. Nothing failing I can find almost like a gear whine in the 64 Chevy II. Just annoying with a/c on you can't hear it but it is still there. Would not expect this in $67K car.
Old Feb 26, 2009 | 01:05 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
This happens on all of them pretty much. I think they clean something with the rails, but it doesn't go away, just comes back. Man, my friends dad's SL55 has the pano roof and it sounds horrible and loud. I mean mine I can't usually hear when I have the music on.
Konigstiger, I remember you posted something in regards to the cleaning of the pano roof.
Old Feb 26, 2009 | 01:50 PM
BlackFox's Avatar
Yeah, but that's a different noise, I've already had that one and the dealer actually solved it by lubricating it
This one is different, it's a real rattle from the interior, I think from the ceiling light unit.
Old Feb 27, 2009 | 06:44 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
I have 1 that comes and goes, it isn't very loud, but being the most audible, it can urk me something fierce. It comes from right around the right post of my driver side sun-visor, like it's the way the interior cloth sits against the metal of the roof or something, almost sounds like very light popping popcorn when it's audible at all. Anyone experience this??
Old Feb 27, 2009 | 11:05 AM
BlackFox's Avatar
Thanks to the pdf files I received from konigster (thx mate!), I've been able to fix 1,5 from the 2 rattles
The one in the roof appears to be completly fixed, there was 1 wire at each side which I believe to be the cause of the rattle. I've taped them to the housing and the rattle has stopped so far.
The one in the dashboard is a bit more tricky, the wood was quite a pain in the *** to remove, especially because of my fear for breaking it
The problem was/is the a/c unit as I expected. I think it's plastic vibrating against other plastic (around the area of the speaker), or just against the dash itself.
I fiddled about with it without actually doing something, screwed it tightly back in place and the vibration is definitly a lot less, but not completly gone.
Old Mar 3, 2009 | 06:48 PM
jameson75's Avatar
2005 E500 / 1993 MR2 Turbo
Rattles are annoying....started to get my first rattles. Seems like its coming from my instrument cluster, namely the plastic cover over my instrument cluster. I just turn up the radio..
Old Mar 3, 2009 | 07:53 PM
Polar Bear's Avatar
Yes - none in mine yet. That is one improvement over the W210 - the sunroof shade rattles in the W210, along with the rear headrests in some cases.
Old Mar 16, 2010 | 04:08 AM
Steve 90TTZ's Avatar
2003 E55
Hello Blackfox and konigstiger,
Any chance you have a copy of the pdf document you used to help fix your panoroof rattles?
Thanks,
Steve
Old Mar 16, 2010 | 04:26 AM
BlackFox's Avatar
Sorry, I've formatted my computer a while back and forgot to backup my documents, I'm afraid the pdf's are lost
The rattles are back though, it's driving me clinicly insane
Dashboard rattle goes away for a couple of minutes if you punch it, or if you push down on the piece between the a/c unit and the clock housing.
Pano roof rattle is incredibly annoying, seems to be coming from the rear part of the roof or the rolling curtain. Don't have an idea how to fix it...
Old Feb 18, 2012 | 10:51 AM
Gates's Avatar
2005 Mercede Benz E320 4matic
Angry Rattle on panoramic roof on my e320 2005
Can someone help me how to fix my rattle noise on my roof between the front slidding and rear glass of the panoramic roof, sounds like a cracking noise in the back driver side and litteraly plays on my nerves! Everything works perfectly but that noise.....
Old Mar 26, 2012 | 02:23 AM
sub786's Avatar
2003 e320
May be you have 2 rattle snakes under the dash
Old Mar 26, 2012 | 09:08 AM
vettdvr's Avatar
Plastic cover over front speaker? Of course mine makes noise there. PDF ? on how to remove and fix would be great, and appreciated.
