E-Class (W211) 2003-2009
Question about Service - 07 E350
Old Mar 21, 2009 | 02:21 AM
E3504matic's Avatar
2007 E350 4matic
I have a MY07 E350 and I did my first service (service A) at 7717 miles. Now at 111xx miles its telling me I need a C service in 11 days. My first service was done last April. How does this FSS figure out when to bring in for service and for which service to do? Also what would a service C entail?
Old Mar 21, 2009 | 02:48 AM
E3504matic's Avatar
2007 E350 4matic
Well I got into the service menu by using the following steps:
- Switch ignition on (position one);
- MPH display;
- Press the trip odometer reset knob three times consecutively (Voltage display appears);
- Select the Service menu with the + or – button;
- Service indicator displays items (1 – 14);
- Press the menu systems button until the MPH display appears.
and found that its calling for items 2, 9, 12,& 14.
Questions:
-Do I really need to change the combo filter at 111xx miles?
-Does the brake fluid need to be replace with only 111xx miles?
Old Mar 21, 2009 | 07:01 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Combo filter probably doesn't need replacement at this time. Brake fluid is recommended to be done every 2 years. When MB paid for the maintenance they were kind off lax in replacing it; i.e. they replaced it in conjunction with a service but not necessarily at the 2 year mark. What is the build date of your E; should be on the door sticker?
Old Mar 21, 2009 | 12:59 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by E3504matic
Questions: -Do I really need to change the combo filter at 111xx miles? -Does the brake fluid need to be replace with only 111xx miles?
Here's the service sheet
File Type: pdf
Old Mar 22, 2009 | 11:47 PM
E3504matic's Avatar
2007 E350 4matic
Old Mar 24, 2009 | 11:27 AM
Long Islander's Avatar
2018 E400 4matic Wagon
[QUOTE=E3504matic;3421808]Well I got into the service menu by using the following steps:
- MPH display;
QUOTE]
Is there a way to clear the service display indicator when you're in that display, or do you need a code reader for that?
Old Oct 2, 2009 | 04:29 PM
jlnike's Avatar
E350 sport
anyone know the answer to this one?
Old Oct 2, 2009 | 05:41 PM
'71 Pinto
Oil change every 13000 miles or 1 year (whichever comes first), additional work assigned by elapsed time and mileage service sheet recommendations (see post #4).
MY 05 to present actually not FSS but MBMS (MB Maintenance System) service is not based on oil quality but rather fixed intervals - alphabetic designations (C….H) do not represent minor or major services more commonly known as Service A and Service B instead, these codes strictly represent an estimated amount of time required to perform the corresponding service (i.e.: . A = approximately 1 hour, H = 8 hours).
