how can I tell if I can add bluetooth to my car?
You have to remove the false bottom in the armrest, it is covered by a plastic piece with a small rubber mat on it, it has a finger hole in it for removal. It is in the very bottom of the armrest. Once it is removed you will notice several wires and plugs, find the plug that matches the plug on your dongle and plug it in. Some people I've heard say the bluetooth works immediately without version coding but most will tell you version coding b y a dealer is necessary to enable the CP211 to recognize a telephone has been installed.
Good Luck!
It's compatible only with the following models:
2003-2004 E Class (W211)
2004 S Class (W220)
2004 CL Class (W215)
If you have the V-60 based hands-free system installed, I believe what you need is Part # B67875856. This adapter will dock in the armrest cradle in place of a V-60 phone, and recognize your Bluetooth phone once installed.
Check out the following on eBay:
http://cgi.ebay.com/Mercedes-Benz-V6...4.c0.m14.l1262
2004 S Class (W220)
Thanks I just bought the puck Part # B67875856 from my Mercedes dealer today and it worked great with my Blackberry Curve. Here are some pics and thanks again.
I'd like to see where it is installed, and where it is connected. I was under the impression that it was installed under the false floor of the larger compartment in the arm rest, but my dealer installed it in the smaller "clam shell" compartment and plugged it into the underside of the "clam shell" compartment.
Thanks!
Someone has to come up with a cost-effective solution for adding bluetooth capabilities to an '05+ E-Class... Something as simple as bluetooth shouldn't cost 10% of the car's value !
Install the Puck with Tail yourself (15 minutes), then take vehicle to MB dealer for Version Coding. I have the Version Coding instructions, let me know if you need them. You'd be surprised how many MB dealers have NO IDEA this can be done for an 03-04 W211; then again, they'd probably rather charge you $2,000 to get Bluetooth
.Thank You
Nick
Thank You
Nick
