E-Class (W211) 2003-2009
Interior shoe scuffs
Old May 6, 2009 | 01:13 PM
maico490's Avatar
nada
Greetings,
Try as I may to be careful, my shoes/boots are leaving black scuff marks on the carpeting covering the driver's door sill, the lower interior of the driver's door, and on the left front corner of the driver's seat.
Are there any clear coverings for these areas that can help prevent this?
maico490
Old May 6, 2009 | 02:36 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Originally Posted by maico490
Greetings,
maico490
Ya, those things get dirty really quickly.
Old May 6, 2009 | 04:01 PM
Barry45RPM's Avatar
2015 ML 350
Blue Coral Dri Clean Carpet & Upholstery Cleaner will remove the scuffs drom the sills & clean the hell out of your carpet too. Look for the trigger spray bottle... the new cans have a very coarse scrub brush mounted on top. All you nead to use it the spray with a terri cloth towel.
Old May 6, 2009 | 04:11 PM
MBZ16V's Avatar
1987 190E 2.3-16V
Greetings,
maico490
I remove mine and use what Barry is using (Blue Coral) to clean them out. I use the Blue Coral and use a very soft brush to remove the soil with water. Then I use a MF rag to dry off the part.
Old May 6, 2009 | 04:49 PM
CLEK500's Avatar
CLK500, E500, SC400
i think every guy in this forum get this, not only you , my friend. it's hard to keep 'em clean
Old May 6, 2009 | 07:33 PM
hankdotcom's Avatar
2006 E350
Great info to know, will stop by and purchase on my next visit to the local autozone
Old May 6, 2009 | 09:37 PM
TPAbnz's Avatar
2017 E300W
Personally, I agree with BARRY45RPM above. Honestly, do yourself a favor and try a search on this topic. . . you'll learn a lot. Good luck!
Old May 6, 2009 | 09:51 PM
starcarnut's Avatar
06 E350
Okay, don't laugh but this works. I use 3M clear packing tape on dead pedal area and the door sill. It's cheap, reasonably durable and doesn't leave residue. I replace them every couple months.
Old May 7, 2009 | 12:48 AM
Dtv211's Avatar
E320
NOT a bad idea! I was considering changing the entire stone colored carpet and anything that can be stepped on to BLACK carpeting, but the MB parts guy told me it may cost several thousands of dollars. YIKES!
Old May 7, 2009 | 06:55 PM
pinebaron's Avatar
07 E320 Bluetec
Greetings,
maico490
Change your shoes/boots.
Old May 7, 2009 | 08:10 PM
gaazmon's Avatar
Nice, very thoughtful.
Old May 7, 2009 | 09:33 PM
starcarnut's Avatar
06 E350
Thanks, my 911 has light carpet and started doing it with that car to avoid constant cleaning and wear.
Old May 8, 2009 | 07:18 PM
maico490's Avatar
nada
Actually, I really should, as this would be the easiest solution.
