E320 4MATIC with tight-turn-induced rumble
I've got a E320 4MATIC which has suddenly developed an alarming/annoying rumble when I make tight turns. I haven't had the chance to get out in a large parking lot to try high-speed tight turns, but when parking, in drive or reverse, I get a deep rumble that permeates the car.
It's not power steering fluid--that's fine.
And when I was parallel parking the other day, I thought I heard one of the rear tires scrubbing--almost like the rear diff is locked. So I got the kids to tell me, as I turned into the garage one day, when each rear wheel made a complete rev, and one is definitely turning at a different rate from the other (significantly enough to notice).
So... any suggestions? How many thousand am I in for?
Thanks,
Bill
https://mbworld.org/forums/2571251-post86.html
Thanks,
Bill
Whew. $80.
/Bill
Carl
Have you resolved your problem?
My problem appears to be solved after only a flush of the transfer case. It was an expensive flush, though -- $650. The dealer flushed the TC about 2,500 miles ago and I've not had any further problems.
BBB
$650 for a flush of ANYTHING seems outrageous. Do they have to drop the transfer case to do it ? Why on earth would it be that expensive?
Carl
