E-Class (W211) 2003-2009
Euro comand, where to buy?
Old Jun 2, 2009 | 03:23 PM
ssonss1's Avatar
Flying Spur
anyone ever by from the seller "euro-customs" on ebay before? where else can i get one from for about that price range?
http://cgi.ebay.com/ebaymotors/MERCE...ht_1629wt_1561
Old Jun 2, 2009 | 04:32 PM
Benz-O-Rama's Avatar
Just a few threads below the one you just created, there is a gentleman that is selling one.
https://mbworld.org/forums/e-class-w...odule-vcm.html
Old Jun 2, 2009 | 04:34 PM
ssonss1's Avatar
Flying Spur
thanks for the reply, he is pending a local sale, im still waiting for pics from him with the screen cleaned.
Can the video in motion be enabled on all of the Euro comand units? or only the older ones, i thought i read that somewhere...thanks
Old Jun 2, 2009 | 06:16 PM
cocacola's Avatar
W211
Regardless of old or new Euro COMAND (NTG1), Video-In-Motion can be enabled on W211 COMAND with SDS.
Old Jun 2, 2009 | 10:03 PM
ssonss1's Avatar
Flying Spur
good to know, thanks. Would this method also work?
The Engineering MENU is accessed by pressing [MUTE], [END] & [SERV] simultaneously - hold for about 8 seconds. When the MENU screen finally appears press[*],[#],[Left Arrow] and hold it for a few seconds -- the first italicised option on the right will allow you to set the DVD in Motion feature.
Old Jun 2, 2009 | 10:12 PM
sunny_j's Avatar
09 E320 Bluetec
would you know how to enable video in motion on a 2009 w211 comand unit?
Old Jun 3, 2009 | 03:32 AM
cocacola's Avatar
W211
This method you provided works only if the Euro COMAND has firmware "SW-Rel 9.390 Build 17/04 announced at 26 Nov 2003" or older installed. Otherwise, (i.e. "SW-REL 21.090 30/06 announced at 18 Jan 2007") any newer firmware currently not possible to get in Engineering MENU to unlock VIM, even latest SDS has removed the option to enable VIM.
However, if someone still has the old SDS with Developer mode enabled, it can still be done. I knew that because I have "SW-REL 21.090 30/06" firmware installed and VIM unlocked using SDS at the same time.
Old Jun 3, 2009 | 03:38 AM
cocacola's Avatar
W211
2009 w211 has NTG2 COMAND. Unfortunately, currently is not possible to enable it with software solution. Maybe you can buy an after market adapter to enable VIM.
