How many miles on your W211?
Going to change the plugs, wires and fuel filter this weekend. GREAT car!
81,000 miles
To much to list for issues unfortunately which is to bad because I go out of my way to take excellent care of the car and replace any parts before they should go bad yet I still have bad luck.
3) Broken sunroof wind deflector; and KEYLESS-GO Rear Door Handles (both of them) malfunctioned (at first, lock button didn't work & unlock paddle would lock the door... eventually no buttons worked at all). All fixed/replaced under CPO extended warranty. Most recently, main battery died & wouldn't keep a charge. Dealer charged $286 to replace battery.
All minor nuisances in my opinion. This is my 2nd W211 (previously 2003 E320). These are GREAT cars.
On my 2003, at 92000mi, my lower front ball joints were sloppy causing the car to pull and chew through tires. NOTHING else was wrong with it. Very solid otherwise.
2) 140,000 miles
3) no major problems although during a recent service my indie said he wanted to investigate some fluid leaking "inside" the engine.
97,000 miles
Routine maint. one broken wheel from an unseen pothole.
We really enjoy cross-country trips in our Iridium cocoon.
2) 139k
3) - 55k All front suspension ball joints replaced under warr. Valve cover gaskets
- 60k Cam shaft sensors
-130K Engine mounts
-139K Front struts
Excellent car, we love it
150.000 miles
Only normal maintenance. Did preventive (steering flush, differential flush) Only fluids from Germany. And oil change every 5K miles with 0w40 Mobil1 and only Chevron 91 Gas for both cars.
My brother's E320
320.000 miles
Only expensive repair was SBC system. Changed engine chain on 300.000 miles. Still original transmission with no repair jobs at all (one time ATF oil change)
1) 2009 E550
2) 62,000 miles
3) Left Side Seal on rear differential was leaking. Covered under extended warranty.
