Rear spacers pros/cons safety issues?
would having only rear spacers affect the safety of the drive? (high speeds highway or cornering etc)
are there any pros/cons of having rear spacers in?
thanks!
i dont think they are hubcentric, thats what the person at the shop sold me them told me. is that the reason why there is shaking?
from the sounds of it, it seems like this problem can be fixed with the right pieces?
with the correct spacers you can take the car up to top speed w/o any issue's. post before and after pics of your car when done
is it possible that he doesnt have the right spacers and thats why hes saying this? im ok with going out and purchasing new spacers online or another shop but can you guys let me know exactly what i need to buy in order for it to not shake?
thanks!
so its H&R trak+
the box is all in german
theres a tag it says automotive wheel spacer DR-System 20mm 112/5, 66,6 mm MERCEDES
and then stock: 2055665
not sure if that helps?
i got it from SR Auto Group
actually i just looked on the spacers themselves it says:
1055665 D made in Germany 09/07
:S
so its H&R trak+
:S
http://www.optionimports.com/2055665.html
http://www.jlevistreetwerks.com/Merc...3s7a5lh5cd4fu6
http://www.optionimports.com/hr-****...350--ml50.html
http://www.product-finder.net/allspr...acers-483.html
There are a few things to consider:
As you push wheels outwards you are changing the suspension geography.
As you push the wheels outwards using spacers you are adding another possibility of vibration. Since the wheels are now further outward, that vibration is amplified.
How to fix it? Make sure that you are using the proper spacers. Balance the wheels with the spacers installed on the wheel - marking the location with chalk so that they can be lined up properly after the balance.
Try a road force balance if the wheel doesn't balance out perfectly.
Make sure that the lugs are properly torqued.
Good luck...
he said i just had to balance my wheels.
dont know if im going to get around to putting them back in and balance them again :S
i think im just gonna stick with just 10mm in the rears and nothing in the front for now
