E-Class (W211) 2003-2009
center arm rest delaminating
Old 09-28-2009, 04:17 PM
SAguirre's Avatar
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
Could someone post a picture of this? Is this on the butterfly center armrest?
Steve
Old 09-28-2009, 04:37 PM
cmarshack's Avatar
GL450; Audi Q7 sline; GX470-SOLD, E55-SOLD, Range Rover Supercharged-Sold
Steve
Here you go...
Old 09-28-2009, 04:47 PM
vettdvr's Avatar
03 E500 and Corvette
Looks just like mine!
Old 09-28-2009, 04:55 PM
SAguirre's Avatar
OK, mine is not doing that yet. I first thought that it might be on the center armrest that looks like a roll-top desk, but I see that it is the one that I have. I wonder if it is extreme heat that is causing this.
Thanks for the post!
Steve
Old 09-28-2009, 10:35 PM
cmarshack's Avatar
Steve
Not the heat...this car is a California Coastal car and i know that it's been garaged at home and at work. I also saw a VERY babied 2005 that had the exact same problem. I think pressure from the elbow just causes the adhesive to pull away after time.
There has to be a way to fix this...anyone
Old 09-29-2009, 06:44 AM
K-A
K-A's Avatar
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
One of the reasons I'm happy to have the wood roll-top center console.
Old 10-21-2009, 05:57 PM
  #32
cmarshack's Avatar
Originally Posted by cmarshack
Here you go...
OK, so I broke out my wife's cheap little travel hair dryer and heated the area up pretty hot. Then I was able to massage the bumps away
I am not sure how long it will stay like this, but right now it looks GREAT!!!
Old 10-21-2009, 06:09 PM
  #33
Efivehundred's Avatar
06 E55(SOLD), 03 E500(SOLD)
Nice! It looks so much better without the bumps.
Old 10-21-2009, 10:33 PM
  #34
K-A
K-A's Avatar
Nice.
Old 10-23-2009, 11:11 AM
  #35
wampa's Avatar
E500 & ML500
Is it possible to retrofit the new style roll top console, into the earlier models that came with the butterfly arm rest? I know that their are electronic parts located in the top of the butterfly arm rest. Will that play a part in the switch, or will it be an easy swap?
Old 10-23-2009, 12:01 PM
  #36
fortlaudsummer's Avatar
W211 Elegance Saloon
This was my thought as well
Old 10-23-2009, 04:23 PM
  #37
SAguirre's Avatar
I wonder if you reactivated the glue (with the heat) or if you made the plastic regain its memory and it because tight again. Either way, it looks like it did the trick and lets hope it lasts for a long time. I hope this does not happen to mine, but if it does I know what to do.
I have already seen a few of the roll-tops with cracked wood, so I don't know which design is better. I really like the cooled compartment in mine!
Steve
Old 11-04-2009, 10:46 PM
  #38
Hubi's Avatar
S550, E320 Sport Wagon and A170CDI :)
thx
just did it in my e320 and the bubble is gone....thanks
Old 11-06-2009, 10:10 PM
  #39
cmarshack's Avatar
Mine came back...I think that the glue get
reactivated by the heat but then fails again because it is just no good any more.
Old 11-07-2009, 06:34 AM
  #40
vettdvr's Avatar
Mine came back also. :-(
Old 02-02-2010, 06:07 PM
  #41
boghos's Avatar
2004 e320
Great mine is starting to do the same thing. Was anyone able to get this fixed?
Old 02-02-2010, 06:43 PM
  #42
Hubi's Avatar
I did the cmarshack's hair dryer trick about 3 months ago and it fine right now....
knock the wood
Old 02-02-2010, 06:58 PM
  #43
vettdvr's Avatar
knock the wood
I did it also with hair dryer and it bubbled up and is worse than before.
Old 02-03-2010, 04:10 PM
  #44
boghos's Avatar
2004 e320
Yikes... maybe ill wait till it gets even worse then ill try it.
Old 02-03-2010, 11:46 PM
  #45
skokkosis's Avatar
2014 E63-S, 1987 190E 2.3-16, 1985 325E
GUYS! [hello, im back for good once again, been really busy] NOTHING compares to the bump that has formed on MY car im going to post up an image and you guys will see i will be trying the hotgun/ice trick if it helps mine.... then its bound to help many!
Old 02-04-2010, 01:32 AM
  #46
skokkosis's Avatar
OKKKKK so after an hour of working on this mo*****ckaaaaa lol its down by a LOT here are b4 and after pics hope people can give me advice for the part i have left [sorry for bad quality pics i used my iphone, ill take good pics to show u the part left in more detail 2maro] i also used an iron on top of a wet cloth over the leather i wasn't making a good process with just the hair dryer if i had a hot gun perhaps it would do the job but here it is
[before]
[after]
all that's left is a SLIGHT long thin bubble along the edge i cant get it out b.c. i cant curve around it with the ice b.c. the ice is flat b.c. of this it will probably start bubbling up again, but its WAY better than before mabe ill think of something to hold that curve in place somehow
Old 02-04-2010, 01:35 AM
  #47
skokkosis's Avatar
boghos look how mine came out, vettdvr you're probably doing it wrong especially if yours is smaller than mine you need to heat it and then immediately apply the ice this change in temperature is what caused the shrinking, this process isnt about heating the glue under and then freezing it, it's to shrink the leather to a small size to cause it to tighten around the area that has bubbled
Old 02-04-2010, 08:37 AM
  #48
vettdvr's Avatar
I missed the part about the ice. I was thinking it would shrink like a polyster airplane covering. When the airplane covering has heat applied it shrinks. Didn't realize ice was being used to make the shrink. I will try that.
Old 02-04-2010, 11:32 AM
  #49
You gotta love science!
I think after you fix it, try to avoid applying lateral pressure with your elbow as this is what most likely causes the stretching
Old 02-04-2010, 11:40 AM
  #50
skokkosis's Avatar
i haven't gone to the car as of last night when i fixed the bump, but im assuming by doing the process correctly and the cold temperature nyc has that it should have gotten cold enough to stiffen it even more than the ice, even if i don't have the heater over it... hoping it's like my images still then yes thank science if not ill just work at it a bit more try to get that bubble on the edge i have left completely gone and just work at it everytime it bubbles it is DEFINTELY better than before, i had so many people coming in telling me "wtf is this?" and then finger the bubble lol and many others giving my input why it's there and how to get rid of it that sounded stupid (oh just open open it from under and pull it tighter... sigh im not that stupid) lol
Quick Reply: center arm rest delaminating
