Why is tire pressure so different front 2 back?
Any ideas? Just curious.
If you equalize to the higher pressure, you may get slighlty better MPG but I think the ride comfort may suffer a bit.
There are two reason for this; to introduce understeer in the car to make it safer for ham-fisted drivers and also to compensate for the weight of the engine in the front.
I guess I could buy the safety aspect by lowering the tire pressure up front but isn't there better ways of implementing understeer? Running low tire pressures, as others have stated, is not usually good for mpg or tire wear. Seems more like a last minute engineering fix than a well thought out understeer solution by Mercedes. This also seems curious, if it is indeed the case.
P.S. How many of you have had someone else fill your tires and when you check them (imagine how many drivers don't), they are all at the same 35psi or more, all the way around? Seems like the bone heads at the tire store or the service station would know where to find the correct air pressures for your vehicle by now. This obviously would negate any attempts by Mercedes to control understeer in their vehicles.
I always pump up the front air pressures a couple of notches closer to the rears in all my cars to (hopefully) induce a more neutral stance - not that I push the car hard enough in daily driving to appreciate the difference
Higher weight due to engine in the front = lower pressure in the front.
You walked in on that one eyes wide open.
Keep us posted on how this is working out for you. I was thinking about trying this out but it makes me a little uncomfortable that I can't just fill my tires with air whenever I need too.
