E-Class (W211) 2003-2009
Glycol test - Tranny problems '03 e500
Old Jul 22, 2009 | 12:32 AM
gkoj4golf's Avatar
2003 e500
I have a 2003 e500 and am taking my car in this week for a glycol test. I've been experiencing glycol contamination symptoms (I didn't know befoer I read older posts). My car is vibrating/droning etc at really mild acceleration at about the 1200 rpm mark. I know there are people that have already changed out their transmissions but I was wondering if anyone else was going through this problem now. I though maybe we could compare notes and findings.
Old Jul 23, 2009 | 10:50 AM
MercFiveHundred's Avatar
2014 E550; 2003 E500
I am also but i got a negative glycol test. Update us on what happens. Search for my thread "Dead end tranny". Those are my symptons and what ive done, but the problem still persists.
Old Jul 23, 2009 | 12:58 PM
mcleantmw's Avatar
2003 E500 Benz & 2015 BMW M235ix
There are loads of threads and postings, such as mine, about this issue with the earlier W211 models you can do a Search for, especially the 03 Es. You can get the MB Tech Service Bulletins on transmissions......there are 2-3 of them, but the main one relates to the faulty Valeo radiator which causes coolant to enter the transmission and torque converter. There's another bulletin on the transmission electronic control module. I've had my radiator and torque converter replaced at the 40k mileage and the ECU replaced about a year later............seems to operate fine now with almost 70k miles on it but I do plan to have my transmission fluid changed every 40k miles for now on as a preventive maintenance approach.
Old Jul 23, 2009 | 06:48 PM
gkoj4golf's Avatar
2003 e500
Thank for the info. I read through the thread. Is the TCM part of a recommended fix or a separate issue all together? I did a search but did not see one regarding symptoms and replacement of just the TCM without glycol issues. Most people seem to go through the entire list of could be's and the TCM is included in it.
Old Jul 23, 2009 | 06:51 PM
gkoj4golf's Avatar
2003 e500
I'll also update. They still think it's a air mass sensor and are doing some more checking today. I've ordered a glycol test kit thanks to some info from KONIGSTIGER. They haven't called me with results yet. I guess I need to do the glycol test in a hurry. I don't want to be the guinea pig as they go through a bunch of "I think this will fix it" repairs.
Old Jul 23, 2009 | 08:04 PM
mcleantmw's Avatar
KONIGSTIGER has access to all the MB Tech Service Bulletins and he'll send you those that relate to your year/model vehicle if you PM him your email address. As I recall, the TCM has a separate Bulletin. But I'd bet you have the contamination issue.........that's the first thing to fix and then if there are still shift problems, you go from there to look at the other issues.
Old Jul 23, 2009 | 08:59 PM
How many miles on your car?
It most likely glycol if its under 65k. My problems started at 120k.
Old Jul 24, 2009 | 03:06 AM
gkoj4golf's Avatar
2003 e500
53K miles.
Old Jul 27, 2009 | 10:28 PM
Update?
Old Jul 28, 2009 | 03:22 AM
gkoj4golf's Avatar
2003 e500
Received the car back today. They said they disconnected the (not sure how) torque converter and it drove fine. They suspect the damage if any is at the torque converter. Waiting for a glycol test of the ATF for something conclusive. I will try and approach a dealer in hopes of a goodwill repair of some sort. I'll update again when i get the result of the glycol test with the extent of contamination.
Old Jul 28, 2009 | 09:25 PM
Torque converter? I think if it was the torque converter it would slip. It doesn't slip though, right? I dunno. It's definitely an electrical problem (if ur glycol test turns out negative). When i disconnect & reconnect my battery it is fine within the first mile, but comes back. I've done this on may occasions and there is an occasion where i took it to my mechanic and it stopped doing it. But acted up again the next day. Did you ask them about the MAF sensor? My mechanic wanted to change it, but after he hooked up his computer, he changed his mind. What about speed sensors? i got a code once that the front and rear speed sensors dont agree - changed the valve body and same problem (battery disconnect fooled me again at first LOL). I dont know if i should spend more money on this car because all i hear is "i dont know whats wrong so you might need a new tranny" LOL.
Old Aug 2, 2009 | 05:05 PM
Did you get the results back Golf?
Old Aug 2, 2009 | 05:31 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
53K miles.
My tranny went out at about 48K miles due to glycol. They changed tranny, cooling lines, radiator. I don't think they changed the torque converter as MercFiveHundred said, it would slip, and I don't remember it slipping at all.
Old Aug 3, 2009 | 03:40 AM
gkoj4golf's Avatar
2003 e500
No results yet. Sent it to Blackstone (rec from Konigster) and haven't received anything back yet. I'll update as soon as I get it. Fingers crossed...
Old Aug 9, 2009 | 11:50 AM
Almost two weeks and nothing back from Blackstone? LOL. I got my glycol test done at the dealership that i bought the car from and they waived the fee for it (and i got a 09 R350 loaner for the weekend). They did it in like an hour but as i said no glycol. I don't know about crossing your fingers, because it may be just as bad as glycol . As for myself, i've been driving it as is, not getting worse nor better. With the mileage in it, i might as well trade it in as cash for clunkers! LOL
Old Aug 9, 2009 | 02:59 PM
Jen_Kenne's Avatar
my wife wild, but she loves every minute of it.
Is there a list of the symptoms of glycol contamination?
Old Aug 9, 2009 | 03:04 PM
Jen_Kenne's Avatar
There is no mechanical connection between the two halves of a torque converter. I doubt there is any way for them to disconnect a torque converter. It sounds like they are blowing smoke at you. I found this vido on youtube that explains how a torque converter works.
http://www.youtube.com/watch?v=MvLoX0z9qoY
Old Aug 9, 2009 | 04:53 PM
konigstiger's Avatar
'71 Pinto
Not certain if gkoj4golf requested a goodwill test from dealer but not all dealers are willing to waive the cost especially in today's economy.
Old Aug 9, 2009 | 04:56 PM
'71 Pinto
TC clutch can be deactivated with SDS.
Old Aug 9, 2009 | 07:07 PM
Jen_Kenne's Avatar
I thought they split up in 1968 and spun off into the SDS-WSA.
Old Aug 30, 2009 | 01:57 AM
gkoj4golf's Avatar
2003 e500
Sorry for the delay. I was out of town. I received the report back from Blackstone. There seems to be some antifreeze in the ATF fluid. Potassium is 16 and Sodium is 46, both properties in antifreeze. I haven't done anything to the car yet in anticipation of the worst (glycol contamination) so I guess now I go through and start with the radiator and work my way through the tranny.
I haven't approached dealers with a goodwill repair but I am not hopeful. I'll try a few (w/ report in hand) and see what they. I'll also look for an indy to do the work.
I guess the next question is how to proceed... Radiator and torque converter first?
Old Jul 8, 2011 | 05:01 PM
bhongjr's Avatar
E500
My mechanic mentioned using a radiator sealant. Has anybody tried this? Any sealant recommendation?
Old Jul 8, 2011 | 07:06 PM
vettdvr's Avatar
03 E500 and Corvette
Engine/Transmission mounts will cause the same problems. Mine failed at 80,000 miles.
Old Jul 8, 2011 | 07:07 PM
vettdvr's Avatar
Call them. They are great I use them on my aircraft engine.
