MB tire and wheel protection warranty for AMG 18's
they have offered up to 5 year plans. are they with unlimited mileage? Do they try to patch or plug instead of replace if they can? Is it pro-rated at all for worn tires? if not, whats to keep someone from purposely ruining them at the end of its tread life? do they match the brand and model of other existing tires or just give you whatever tires they have in stock? thanks
They will patch if possible, or replace if needed.
Tire must have 3/32" tread life of better remaining to be covered.
For wheel repair/replacement it MUST NOT SEAL AIR.
IIRC, the cost for the wheel/tire warranty was around $600 for 5yr/50k. I would recommend it with MB's "soft" cast wheels that were designed to bend with low profile tires to protect the aluminum suspension components. If you have runflat tires, the wheel/tire warranty is a must!
I try and avoid every road defect, but there is always that one you cant avoid...and those can be killers!
Your prior posting indicates that there are "soft" cast wheels available that are stronger than the alloy wheels. Are they AMG wheels that will match the other wheels on the vehicle?
I found a place to repair the small fracture for $125.00. The repair shop is a large nationwide company with a franchise in my area. I will see how that works out.
