Newbie Purchasing 2003 E500
If you guys would stay away from this deal let me know. The body and the interior are mint. But at that millage is there a huge service that has to be done soon? And how is the air suspension on this car.
Thanks Allot. Any Feedback would be appreciated.
09/06/2002 US Customs Vehicle imported to
Baltimore, MD
37,420
Power steering fluid leak checked
Power steering pump replaced
Power steering checked
Rear shock absorbers replaced
Maintenance inspection completed
One wheel replaced
Wheel lug studs replaced
Fuel injection system checked
Engine/powertrain computer/module checked
Fuel system checked
Air flow meter replaced
Engine checked
Front license plate bracket replaced
Ball joint replaced
Lower ball joints replaced
Idler pulley replaced
Computer checked
Electrical system checked 38,500
A/C compressor replaced
A/C compressor repaired
A/C refrigerant recharged 42,062
Transmission checked
Engine/powertrain computer/module reprogrammed
Front turn signal/parking bulb replaced
Turn signal(s) repaired
Computer reprogrammed 12/31/2005 43,790 Stabilizer bar links replaced
Body electrical system checked
Brake fluid flushed/changed
Manufacturer's recommended maintenance performed
Newer is definitely better when it comes to W211s. Yes - on paper it's a lot of car for $14K but to be brutally honest if that is your price range IMO you won't be able to afford to keep it running.
What about any service/repair records from the 44k to the current mileage. Does the PO have them?
Whatever car you end up choosing, be certain to spend the money to do a full ppi including paint meter and body check. No matter what Carfax says and where the car comes from.
There are lots of cars to pick from out there and as a buyer you have the upper hand. Try to be patient.
