HELP! '04 E500 "Crashy" Front Suspension...
I've got an '04 E500 Wagon that seems "not right" in the front end. The car is under a CPO warranty and has 48,xxx miles. I have searched, searched, searched, and have found various symptoms that sound familiar, but not exactly like my situation, and the car has been to the dealer multiple times for multiple days with no positive effect.
The symptoms: Over various bumps (manhole covers, ripples in the road, big potholes), the front end, particularly the drivers side, sounds/feels "crashy" or "sloppy" or "clunky". I can feel a secondary bump in the wheel/in my foot when on the dead pedal in more severe situations, but on lesser bumps I can audibly hear a clunk. This is more prounounced when I hit the bump on the drivers side vs. the passenger side. It doesn't rattle, squeak, shimmy, wander, pull or do anything else that would indicate a problem. The sound makes the front end "sound loose", even when it doesn't "feel loose", if that makes any sense. If this were a conventionally suspended car, I would probably say it could be a bad shock absorber or strut top mount...
It does not seem to matter if the Airmatic suspension is set to Comfort, Sport I or Sport II, although for some reason I feel like it's less pronounced in Sport I, but I suspect that is in my head.
My dealer says nothing is wrong, they can't hear anything, everything is fine, etc. An upper control arm was replaced early on in the diagnosis, but nothing else has been repaired in the suspension. Also, motor mounts and trans mounts were recently replaced after a vibration began in the exhaust system. The problem was around before the mounts were replaced, and remains afterword.
I have a hard time believing that an "executive" class car with a high-tech air suspension and a $70k new pricetage should make any suspension noises if things are in working order. My '95 E320 with 250k miles and a conventional spring suspension is quieter over the same bumps.
My thoughts variously have been sway bar bushings, loose subframe bolts, loose steering column... Maybe it's nothing to do with the suspension at all, but some other component that is mis-adjusted, loose, etc.?? Again, dealer indicates nothing is wrong. I just don't know what's up and the dealer is useless.
I throw myself at your collective feet for your wisdom!
Thanks,
Gavin
Thanks,
Gavin
Talk to the shop foreman rather than your SA? Find some other threads from this forum about the same problem and print them out and give them to him to read.
Last step, take it up w/ MBUSA.
"The squeaky wheel gets the grease."
R.J.
