Rim spacer help, 19x8.5 !!!!!!
I ordered some concept one RS-8 rims in 19x8.5 from D2autosport 3 wks ago. Finally got them Thursday. Took them to Sears and NTB and both tire techs said i need spacers. Watched them put on the rim to the hub and there is a gap, (not sure how much mm gap), but obvious.
Since the 19s are bigger and have a gap (not sure how many mm). They refused to install due to possibility of it wobbling and could some loose.
Its been hell working with D2autosport in getting my rims.
1. Said they were in stock and would get them in 3 days. Further research on my part i find out that the RS-8 come in 5x114, not 5x112. So when i confronted them on it, they said they would file down and had adapters and make them fit 5x112 pattern. Then said they were being special ordered 5x112 which took 3wks...
2. Asked if i needed spacers and they said no and should fit without issues. (guess i had to find out the hard way!!)
3. get the rims and see that the stamp on them say ET 38. But i need 35 offset to fit my benz. Called them and said that its the stock stamp and since they were custom fabricated, its not et38 thats stamped on the rim but offset to fit my car.
One good thing out of this is that i did dispute my credit card company for the charges that hit. Really crap customer service from them. I wouldn't suggest ordered from them at all.
So if you did a chargeback, are you sending the wheels back or keeping them for free?
I've had nothing but great service from D2 Autosport. Customer service was above and beyond.
i'll give them 2-3 business days to resolve the issue , since i didn't get the "above and beyond" service that i would hope. It was like pulling teeth to get info on the rims after i paid for them.
-so i contacted the maker of the rims to help me resolve the delay.
- Asking them what bolt length i needed, was told your installer should know...
-what offset are for my car, was told 35mm then later told i never told you what the offset is for your car when i brought up the 38ET stamped on the rims....i mean WTF tell me one thing, and later say something else.
I don't know the history of your transaction, but I would pick up the phone and call Derrick. I have a feeling that this has been one huge misunderstanding that they'll be eager to resolve.
Whatever happened, good luck in getting it resolved. I bet it'll all work out.
As for the customer service, I have answered every question you asked, accepted responsibility for any lag, and apologized for any shortcoming on our part. I told you the wheels wouldn't require spacers and they don't. Its hubrings that you are talking about, and they simply center the wheel on the hub. Totally different than a spacer which pushes the wheel out futher from the car.We even paid extra to have your wheels done by Concept One, when our local supplier said they were in stock, and then they were not. Our supply issues are not your problem, and I don't personally believe in excuses in business, so this is the reason I never even bought this up. Do I want a medal or extra acolades? Of course not, that's what is done in the name of customer service.
I am well aware of the extra time this has taken, however I have been available to you via phone and email with never more than about a half day response time. Even if you have an issue, we are still being accountable.
With all this being said, we still have not been paid for these wheels, since you froze the charge. Yet I've offered to send you more hubrings just to make this right. If you don't consider that good customer service then we'll just have to respectfully agree to disagree.
For the record, I still approach this situation from a apologetic perspective, and I sincerely hope we can get this particular situation back on track and earn your business in the future. If not, I respect your decision.
I still have hope that things will work out and in the end, both sides will be happy. I know you've been trying your best to resolve all the problems that i've encountered, but frustrated (i could use other words) could sum up how i feel.
I didn't see any hub rings that came with the rims when i opened each of the 4 boxes. Only thing that came in the box were plastic flimsy center cap inserts and one license plate holder w/D2 logo. I hope these arent the hubrings, because they look very cheap/flimsy vs the extra ones that Sears had laying in their back room that tried see if any fit my car, which didnt.
I'd rather have the hub rings sent to me, instead of Sears (so there is no more mixup of what went where).Hopefully the hubrings you send will arrive soon so i can try again to get the rims put on my car.
Benz-o-rama
I agree that i've seen only positive experience with D2 on here by other members and on clublexus, thats why i decided to go with them. Do i have regrets? Yes/no, maybe....i just wish things were smoother than what i've gone through.
Benz-o-rama
Those center cap cheap and flimsy inserts are probably the hub rings you need. You don't want metal hub rings. Hub rings are only an installation aid (though these don't come out following the install) to center the wheel instead of simply relying on lugs for centering. Try them out.
But the ones i saw Sears had and some research online i did and ordered from (justforwheels.com) look totally different and are more ring like look.
Did get an email from Derrick saying sending me hubrings. And my cc company did let me know they reversed the chargeback. What a hassle it has been.. Next time i'll just rethink before i order for my other cars.
You are correct about vibrations: Centering prevents vibrations.
Box with hubrings from D2 was at my doorstep when i got home from work. Went back to Sears and got them put on. 2 hrs later on the road. Like the way the rims/tires look. Glad i went with the 19s vs 20s. Smooth ride and no vibrations.
Just need to find a way to lower via STARs without going back to factory settings after several key cycling.....don't want to use ELM or lower links, since car is under warranty thru 2013.
I apologize for any hiccup along the way, but as they say alls well that ends well.
As I said before I sincerely hope we can earn your business, and referrals in the future. If not we at the very least got you what you wanted 100% and I'm most comfortable with that.
-Derrick
