E-Class (W211) 2003-2009
Old 06-12-2015, 07:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
No power to trunk, 3rd brake light, or license plate lamps
Rating: Thread Rating: 4 votes, 5.00 average.
Old 04-01-2014, 05:31 AM
  #51
tonypll's Avatar
mercedes E270 cdi Avantgarde
Smile mercedes E270cdi avantgarde (broken wires)
i stumbles across this forum whilst looking for a solution to my boot lid not opening and licence plare lights out and 3rd brake light not working.
many thanks to all for the posts that made my life so much easier as to the problem fix, i too had 3 wires broken and repaired them with very little time and effort!
it cost me nothing as all the things i needed were already in my toolbox...
tony in yorkshire uk.
Old 04-01-2014, 07:04 PM
  #52
AMGAffalterbach's Avatar
2014 BMW M235i
Glad it helped! (Not that I was a contributor lol) Welcome to the forums Tony!
Old 04-25-2014, 04:54 PM
  #53
swindon_taxi's Avatar
e220 exec
different area but found a severed BROWN wire and now all sorted
Why is it always a brown wire?
Old 04-25-2014, 04:56 PM
  #54
e220 exec
Found the BROWN wire and hay presto all sorted now
Old 04-29-2014, 12:47 AM
  #55
mbnnrh's Avatar
08 E350 4matic
Post helped me solve this problem. It was brown wire for me as well.
I wrapped the entire section of wire in the area of the repair with electrical tape. Then, I reattached to the swing arm with a zip tie. However, I left some slack in the zip tie so the wires can move freely without getting severed again.
Now, I must repair two other issues. 1) The Brake/Stop Light Switch issue and 2) I have received the temperature stop car immediately message twice in the past week.
Old 05-18-2014, 10:36 PM
  #56
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
Just happened today.
We are away on vacation and almost had golf clubs locked in the trunk.
This is the first time I needed to use the trunk key and of course set of the alarm.
Hopefully it is the simple fix like everyone else.
Old 05-19-2014, 03:10 AM
  #57
2014 BMW M235i
^I had that when my battery died, nothing worked except for the alarm apparently and when it didn't recognize my key fob I ended up setting off the alarm a few times in the process of getting the car jumped. A bit embarrassing lol
Old 05-20-2014, 07:11 PM
  #58
N_Jay's Avatar
Took me about an hour going slow.
I had trouble figuring out all the pieces that need to come out to loosen the side panel. There was even one bolt.
I used a butt connector, covered it with heat shrink, then wrapped that bundle about 2 inches in and out of the loom.
Then started past the loom and wrapped the outside to keep the loom end from moving.
Don't go crazy as it still has to fit under the hinge cover.
Old 06-24-2014, 06:23 PM
  #59
skipsantos's Avatar
2008 E350 Sport/2016 E350
Brake and License Plate Lights & Trunk Switch
Just bought a 2008 E350 and three days later - left and right license plate lights and third brake light go out along with trunk switch. This fix was dead on. It took more time logging in and searching for the fix than the actual fix itself. Thanks for the guidance.
Old 07-21-2014, 04:32 PM
  #60
ezermid's Avatar
e class
Thank you very much, first i thought that its not real and it was other problem but i want to thank you and to all the forum that gives solves to problems that we never find without the internet!!!!!!!
Old 08-30-2014, 12:46 PM
  #61
aguison's Avatar
Mercedes E350
3rd brake lamp, license plate light left, right and trunk locked
This forum saved the day! I had the identical problems reported in the previous posts - yesterday after stowing my laptop in the trunk after work, when I start the car, there's a message on the center gauge "3rd brake lamp", then would change to "license plate light left", then change to "license plate light right" and kept rotating between the 3 messages. When I got home, I tried to pop the trunk with my remote, it wouldn't open. Then tried opening trunk with the driver door switch, wouldn't open.
Then I googled "3rd brake lamp" and found the posts on this forum. It was exactly what was described - for some strange reason, the brown wire which is part of a bundle of wires attached to the left hinge of the trunk with a plastic tie was "cut". I don't know how, but suspect the black plastic part which covers the left hinge hits the wire as the trunk is opened and closed and over time, it's like bending a piece of wire up and down repeatedly until it breaks.
The way I repaired mine was strip both ends of the brown wire about 3/8", twist them together and solder them. Then just use electrical tape to protect the connection. I cut the plastic tie which supported the wire bundle. Next I used a black 3/8" plastic split loom and wrapped it around the entire wire bundle and secured the wires with a new plastic tie.
Notes:
1. When you remove the left panel cover inside the trunk, you will have to remove 2 plastic fasteners on the side and 2 fasteners on the bottom.
2. I found that I had to remove the plastic panel on the rear as well to make it easier to remove the left panel. There are 6 plastic fasteners to remove.
3. All fasteners were reusable.
4. When you reconnect the brown wire, the car will start honking the alarm. Relax, just use your key to turn it off.
5. Test the car before putting everything back. On mine, it still displayed the error message. I popped the trunk and restarted the car and that somehow reset it.
6. On mine the brown wire severed INSIDE the plastic piece which covered the hinge. I had to remove the plastic piece to get at the brown wire.
Old 09-07-2014, 12:59 PM
  #62
BenzboyW210's Avatar
2007 E550, 2007 GL450
Originally Posted by hbamark
Hi All,
If your vehicle has lost power to the trunk unit, and lights, there is a very simple fix. This is fairly common problem on W211 models. The wires get caught it trunk hardware and get severed. The dealer wanted to charge me $250 for something that took me 20 minutes and less that $10 to complete. Here's what I did.
1. Use the key to manually open the trunk.
2. Remove two plastic pins holding carpet/panel on the driver side of trunk. Pull carpet/panel away carefully.
3. Remove plastic cover on left trunk hinge by unfastening pin at top of cover.
4. Follow the wires until you find where they are severed.
5. Strip wires slightly.
6. Put a piece of shrink tubing over one side of the wires.
7. twist severed wires back together where you stripped and exposed the copper.
8. Solder the wires.
9. Pull the shrink tubing down over the exposed copper.
10. Heat the tubing so that it shrinks around the exposed wire.
11. rewrap wire so that it follows the left hinge in a manner that is will not get cut again. (I wrapped the at risk area in duct tape, not pretty, but it was effective).
12. Reinstall Panels.
Sorry for the lack of pictures, but this is a real easy fix. I hope this procedure saves some $$$ for someone.
Thank you sir! Had the same issue, checked fuses and nothing wrong there. Then Googled the issue and found this thread. Pulled the panel and the larger gauge brown wire (ground?) was severed exactly where you stated. I inspected the rest of the wiring bundle (which should be encased given the physical mechanical movement around it) and it was fine.
I had by chance just purchased a set of both heat shrink wrapping and butt connectors, so I was well equipped to fix.
15 minutes later, all is well. Definitely seems to be a common issue with W211's.
Cheers.
Old 09-09-2014, 01:46 PM
  #63
Bomb_Bay's Avatar
2009 W211 'Last of the Line, 1979 Morgan 4/4
Thanks from a grateful Englishman!
Just adding to all the notes of thanks for this post. Wire severed this morning, my garage knew exactly what it was and told me over the phone. A minute to find this post and 30 mins to fix with 2 bullet connectors and a joiner all wrapped with insulating tape.
Brown wire, down where the plastic tubing finished. Figured out the fixing OK just life the centre tab and they come out very easily.
Thanks again
Old 10-12-2014, 12:56 PM
  #64
georges66's Avatar
2008 Mercedes Benz E350
Thumbs up It's amazing what one brown wire controls
Thank you hbamark for the solution. One brown wire was cut, so I stripped both ends and crimped a connector to them. Problem solved. The hardest part was prying the side wall carpet without damaging it. Saved a few hundred bucks.
Old 01-06-2015, 12:25 PM
  #65
marathonrunner's Avatar
2014 E350, Polar White, sport package
I too want to express my sincere thanks to hbamark for the post. Although getting the side of the trunk liner wasn't as easy as it should have been, I actually had 3 wires that were broken. 2 of which actually broke in 2 places, so there were 3" to 4" pieces laying in the floor of the trunk. Plus, a 4th wire was getting ready to break. Unbelievable that happened. Thank you, thank you, thank you. Saved me much heartache and time & trouble.
Old 01-13-2015, 01:23 PM
  #66
Afarsian's Avatar
E320 bluetech
Brown wire on mine. It brakes right at the tube, i think you should reconsider plastic tube to something softer.
Old 01-13-2015, 01:33 PM
  #67
N_Jay's Avatar
They needed to bring the tub up further so the bending is all in the tube and not at the edge.
They probably should have also used a thinner stranded more flexible type of wire.
Old 01-17-2015, 03:05 PM
  #68
Dandaco's Avatar
Drives an 08 CLK 550 cab, 2013 E350 sport 4matic, 08 Malibu V6
Hi All,
Had the same problem. Followed the instructions. Brown wire was split/broke. An easy fix with help from this post. Thank you sooooooo much!!!!!!
Old 01-22-2015, 02:58 PM
  #69
Sugar_Mouth's Avatar
2014 E63S, 2018 GLC 300
Same issue here.
The wire was hidden under wrap so you may have to pull back the wrap to find it.
Old 01-23-2015, 09:03 PM
  #70
black_e63's Avatar
2007 E63 AMG
This thread is gold, Jerry, gold. I had the broken brown wire as well, and now I am back to "tip-top" shape. Thank you OP and this community!
Old 01-24-2015, 10:45 AM
  #71
tocky11's Avatar
2005 E320 CDi, F350 King Ranch Dually
OMG.. this was incredibly easy to repair, even a women (me) can do it - very good instructions - took me about 20 minutes to repair! Thank you so much!
Old 02-11-2015, 11:16 AM
  #72
philipvrl's Avatar
w211-200cdi
And yet another thanks for this post & solution.
Indeed, the brown wire as well... MB most probably made an error in selecting a wire which is not flexible enough..
Txs !!
Old 02-14-2015, 02:01 PM
  #73
dr2828's Avatar
MBE350
Thumbs up E350 trunk opening, lights, malfunction
Thank you so very much. I saved hundreds of $$ fixing this myself. and I'm not the greatest mechanic but followed your directions slowly and carefully. all is well, used some elect tape, patience, heat-shrink tubing, and now ready to go. My local MB mechanic( not dealer) was closed, called a few auto-electric places and most said, "leave it w us and we'll call you, should take most of a day and regular 'hrly rate' til we figure out what's wrong!" only appts were 2-3 days from now. I appreciate all you people's fine work and time. it was my brown wire as well.
alan
Old 02-16-2015, 02:10 PM
  #74
LakeIce's Avatar
2007 mercedes c230
trunk won't open
Originally Posted by peterroganpeter
[LEFT]thankyou for your help worked a treat great job
I also have no power to my trunk and the key also doesn't open manually and the back seat can't come off unless you get to the trunk I'm kinda stuck here any suggestions?
Old 02-16-2015, 02:58 PM
  #75
N_Jay's Avatar
The key is a little tricky.
I forget which way you turn it, but the trick is to;
1) TURN THE KEY ALL THE WAY.
2) HOLD THE KEY TURNED
3) PULL THE TRUNK RELEASE HANDLE
Try one way first and then the other.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: No power to trunk, 3rd brake light, or license plate lamps
