E-Class (W211) 2003-2009
Crankshaft Position Sensor location on 03 E500. Replacement procedure.
Old Sep 18, 2009 | 12:47 PM
busaman's Avatar
2003 E500 Sport
My car has been diagnosed with the crankshaft position sensor needing to be replaced. Where on the engine is the CPS located and what tools are needed to replace the part? Thank you.
Old Sep 18, 2009 | 01:19 PM
mobinakhtar's Avatar
MY2004 E320
Part is cheap circa $50-$100.
Location is 16" S of steering wheel on drivers side engine compartment
1 8TE Bolt - thats it. HOWEVER need a flexing rachet (30-degree or so and a 11 year old's hands to do the damn thing - there is virtually no space there. you can either see it or touch it not both at same time.
It is accessable from top. I had mine done couple weeks ago - a friend did it gratis. Actually he donated the part too that was in his old flooded engine.
ebay $35-50
dealer $80-$112
one hour labor - and they do negotiate it to 45 mins or less if you are good.
Old Sep 18, 2009 | 01:53 PM
AmazinglySmooth's Avatar
E500
What were the symptoms that you reported for that diagnosis?
Old Sep 18, 2009 | 01:59 PM
MY2004 E320
Sometimes when car was driven for a while and then stopped (like home to restaurant to shop to shop) it would not start on first try. 2nd or third time cranking it will start like nothing happened - no codes either.
If it took more than 3 times it would trigger MIL with misfire codes.
I kept driving like that and them once in odd while it would die at idle at signal lights but would start again on 2nd try or so.
Once it died and wouldnt start again until 20 minutes or so when CPS sensor cooled (I later found thay work fine cool). it was a cheap part to throw at so i did it and since then no issues.
ONE THING TO NOTE THOUGH: IT all started happening the day after I replaced all spark plugs with Bosch+2's. For a while i was playing with plugs, wires, coils thinking it has to be the plugs or something I did. Searching in the forums directed me to the CPS though.
Old Sep 18, 2009 | 04:49 PM
lkchris's Avatar
'10 CL550, '12 GL550
Those are incorrect plugs for your car and should be replaced with those factory specified. +2 Bosch are simply K-Mart specials.
Old Sep 21, 2009 | 10:26 PM
EHop's Avatar
All of them
its more/less below the mass air flow sensor. it gets its reading from the flywheel so its acutally on the bellhousing of the transmission. easiest way is with a long extension(24" or so) and a universal socket. your arm will get cratched up when u reach down to unplug the connector and pull it out.
Old Sep 28, 2009 | 10:09 PM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
awesome post. I'm sure as the W211 gets older, more DIY projects will spring up.
Old Apr 17, 2010 | 09:28 AM
calvin199's Avatar
e500
had some problem with my car
was facing a similar issue with my mercedes e500. Thanks for the help.
Old Dec 18, 2019 | 09:22 PM
jamesjohnst's Avatar
1998 C230
Thanks for the info it helped change one on my 2004 E500
