E-Class (W211) 2003-2009
Tire Pressure Monitor?
Old Sep 30, 2009 | 10:31 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
First Off.....I picked up this E500 and love it! I am kinda annoyed at somethings. I keep getting a message saying to reactivate the tire pressure system. I looked at the manual and I cannot the the screen where all 4 tire's psi shows, it says it is deactivated.....what should i do?!?!
Old Oct 1, 2009 | 01:47 PM
Barry45RPM's Avatar
2015 ML 350
Its possible the previous owner added/removed the system to the car & it needs programming to know its there/not there.
Old Oct 1, 2009 | 01:59 PM
djrabbi's Avatar
I don't know? I got a message on teh dash after driving saying Tire Pressure Monitor is inoperatipal?
Old Oct 2, 2009 | 02:41 PM
Long Islander's Avatar
2018 E400 4matic Wagon
On mine there is no screen that shows all 4 tire pressures. It just tells you to check tire pressures when one of them is low. There's a procedure for resetting the TPMS. Did you try that? it's explained in the manual.
Old Oct 2, 2009 | 02:46 PM
djrabbi's Avatar
i tried too but it says it is inoperatable....soo i cant reset it unless the tire pressure actually shoes up
Old Oct 2, 2009 | 02:54 PM
lkchris's Avatar
'10 CL550, '12 GL550
You have to have sensors in 4 wheels that are working, i.e. batteries have not failed.
Old Oct 2, 2009 | 02:56 PM
djrabbi's Avatar
how would i know if they failed?
Old Oct 2, 2009 | 07:05 PM
konigstiger's Avatar
'71 Pinto
MB dealer or independent can check sensors via DAS life expectancy is 5 to 7 years. Components consist of 4 wheel sensors, 4 antennas in wheel housings and control module located at left side of trunk behind rear SAM. The place to begin would be to inspect wheel sensors that may need replacement. Sensor part #0008224806 (for comparison shopping, parts.com $128.80) and just in case front/rear, left/right antenna 0018274801 (66.70), control module 2115406245 (342.70).
Old Oct 2, 2009 | 08:52 PM
djrabbi's Avatar
is TPMS standard on 03 E500?!?! I cannot see any of the tires pressures, just says inoperatible
Old Oct 3, 2009 | 04:08 PM
'71 Pinto
It is an individual at cost option, you can check out the marketing brochure here http://www.ragtop.org/mbbrochures/ and enter your VIN here http://old.mbclub.ru/mb/vin/?lng=eng (full version) for a list of factory-installed equipment. If any codes come up unknown, PM your VIN and I will send a copy of the MB datacard
