Disc brake replacement
I was just wondering when i need to change my disc brakes. My car is 2003 model and i have only done 35,000KMs/21,700Miles. I just want to upgrade my standard ones to DBA slotted ones
. Being cheap, if my disc brakes need to be replaced soon then i might as well wait
.Now I suppose you want to know the limits.
MY E series Wear limits Front Pads .226 Rotors 1.000
I think you will find the FSS will indicate change much sooner than the MB min they specify. So for me I drive longer than the + and inspect the pads vs. MB spec.
Now you want to be cheap, do the job yourself and USE OEM MB parts from an online supplier. You can replace the pads and sensors for about $80.
BUT
If you want jazzy after market you are on your own but DON'T expect to be cheap. Good parts will cost you in after market. The cheapest way for brakes IMO is OEM MB parts for the least amount of rework, trouble and cost.
For batteries you might find replacements that meet the OEM specs a bit cheaper than OEM but I use OEM for my work.
Somehow Cheap and Mercedes doesn't seem to fit in the same sentence,, oops I just made one.
Also, periodically check the rear pads as only the passenger side pads have a sensor. On my car, the driver's side rear pads wore down so much they started to score the rotor -- I wasn't too upset because I was already planning to replace the rotors with the pads when the time came. Besides the braking system commanding, when the wipers are on, the rear brakes are also commanded to "drag" a little to keep the rotor dry for better braking.
Regards,
paul...
But if you want to buy the slotted you will buy pads at the same time. Try Bremo they usually produce a good product at a fair price for the quality.
. but thanks heaps anyway.
