E-Class (W211) 2003-2009
E RAM SUPERCHARGER
Old Oct 29, 2009 | 05:12 PM
MTIMBO's Avatar
E500 2003
Exclamation E RAM SUPERCHARGER
Hi,
Was thinking of putting an ERAM supercharger on my 2003 E500. Mainly because coming upto summer car seems to be more sluggish compared to night time and during the cooler months. I realise air temp / denisty will play a role also. What do people know about this system and if it is effective for increase power / reduce fuel use?
http://www.electricsupercharger.com/
Old Oct 29, 2009 | 08:20 PM
braizedtofu's Avatar
05 e500 & 11 sti
damn thats the 15 hp one!!?!?!?!?!?!? get that now!
........ you made my day with your post. Warmer temps = less o2 in air = less power. so according to this amazing device..... it will increase the amount of air it flows into your intake tract, even if that were true, the amount of metered air would increase, which would lead to the ecu increasing the amount of fuel injected. how does increasing air (which also increases fuel consumption) reduce fuel use? just some food for thought
Old Oct 29, 2009 | 10:16 PM
MTIMBO's Avatar
E500 2003
Hi. Yeah I wasn't sure about the actual device use to "meter" the air. Does it measure the actual O2 entering the intake as a volume / a percentage or simply measure the output based on CO2 and biproduct production? I was more thinking along the lines of low O2 making the car run lean thus leading to inefficent fuel consumption.
Anyone had experience with these devices?
Old Oct 30, 2009 | 12:58 AM
boardernr's Avatar
05 Lotus Exige; 14 E350 cab; 13 S550
i hear if you line up like 4 or 5 of them then you can start making some serious power, upgrade your muffler bearings, and top off your blinker fluid first though, or else you could get in to a real mess.
Old Oct 30, 2009 | 03:56 AM
MTIMBO's Avatar
E500 2003
does anyone have a normal answer or just trying to be part time comedians... dont give up your day job...
Old Oct 30, 2009 | 04:03 AM
05 e500 & 11 sti
Old Oct 30, 2009 | 04:07 AM
05 e500 & 11 sti
mtimbo, why listen to the "coemdians" that "quit their day jobs"? just buy one and use it.... then let us know how it went... I gave you a good answer, if you don't believe me then find out for yourself.
Also why are you so concerned about gas mileage? trade for an E with a smaller engine, or just dont floor it as much and use less AC
Old Oct 30, 2009 | 05:37 AM
Baron11's Avatar
2008 E320 Bluetec, 2008 GL320 CDI
air density minimal to NO effect on your car...
based on the output and tuning in your car, the air density has an extremely minimal effect on your car. The A/C in summer months has more of an effect. Also when the fuel stations switch over to oxygenated fuel, that too will have an effect, but the air density in a non-turbo charged car, with stock or close to stock output, you won't notice it. I am sure it is something else. I will say this, most european cars that call for premium fuel get better mileage on premium. They can burn regular, but at retarded timing and lower fuel efficiency.
B
Old Oct 30, 2009 | 03:44 PM
JoeVal's Avatar
C350 Elegance
Thumbs down
It's already been proven that the MB OEM air filter provides a better flow than K&N and other miracle conic gimmicks. Do yourself a favor and stick to what you have. If you wish more power, go to a larger or a modified engine. AC will steal power from you in the Summer, but this does not mean that the car motor had lost it.
Old Oct 30, 2009 | 04:50 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
+1. OEM setup is a very good one
Old Nov 3, 2009 | 01:22 AM
boardernr's Avatar
if your sharp enough to realize that I'm messing with you then I think you would be smart enough to figure out that if you put a cheese-weasel electric fan in your intake that it's not going to do jack *****.
Old Nov 3, 2009 | 02:03 AM
05 e500 & 11 sti
I thought you were serious the whole time!!! I just adjusted my muffler bearings and i was going to top off my blinker fluid
Old Nov 3, 2009 | 06:08 PM
mobinakhtar's Avatar
MY2004 E320
Boardrnr - you kidding me? Instead of all this work, he should just upgrade to a bigger hamster in that gizmo.
