I hope I can be helped
on my parents dash display we get the battery symbol and the "visit workshop" They have no other problems other than this warning. The vehicle starts and runs fine. I checked the voltage at the rear main battery and it reads 14.2v. The only thing I have done differently today is, I figured out how to turn the fogs on.
They haven't had the car for very long, I didnt push the knob back in before I turned the headlights back to the auto position, if that makes a difference. They are both school teachers and saved up for a long time to buy there new used mercedesany help is appreciated
thanks,
Steve
had the same red screen and warning last week. It is most probably the small auxillary battery under the hood.This is the backup for the SBC system in our cars, not there in the post 2005 ones. Changed it and the malfunction/warning is now gone.
Hope this helps
Areez
Regards,
paul...
If I read correctly the aux battery is a 14bs. or somthing similar to that?
thanks though,
It is important to remove the surface charge on these (AGM) batteries before taking any test readings as I mentioned before of the numbers will be off.
Regards,
paul...
https://mbworld.org/forums/e-class-w...-workshop.html
