help rims not fitting right
2003 e500
Just got new set of e63 amg rims for my 2003 e500. the backs fit no problem but on the fronts the dust cover where the grease is on the front axle sticks out to far so the center hub cap cover dont fit. Is there a way to fix this. thanks
Are they true OEM E63 AMG wheels or are the rep's? Where did you purchase them? My guess is they're reps. I have OEM E63 P30 wheels and they fit with no problem.
2003 e500
i am all most positive that they are oem the have the amg symbol on it. They fit good it just i cant get the hub cap cover on any ideas.
Where did you buy them?
2003 e500
rim dealer up in north jersey. rims are on car currently so have to wait untill tomorrow to check the part number. would it be that my car is a 2003 and rims are 2009
I thought you said that the fronts wouldn't fit? So how can they be on the car?
The AMG wheels from a 2003-2009 W211 will fit on a 2003-2009 non-AMG W211 without drama.
You bought them new? How much? This will tell you for sure if they're true OEM AMG wheels.
2003 e500
Only MB dealerships have access to OEM MB wheels. Your rim dealer in North Jersey sold you reps.
2012 CLS63
Those aren't E63 wheels. You should have purchased the set I am selling. True OEM E63 wheels with tires. Those look like stock W204 sport wheels.
For instance: My OEM MB E63 030 wheels retail for just shy of 10,000.00. Now, these are 2peice wheels and completely over priced, but you get the idea. But I don't think there is a set of any OEM MB wheels that will cost you less than 3000.00 for the set, if they're real. At first glance, they look an awful lot like these cheap reps:
http://cgi.ebay.com/ebaymotors/18-x-...Q5fAccessories
2003 e500
I don't think I've ever seen those wheels on an E63 before. Again, how much were they? That will go a long way in figuring out if they're an OEM MB wheel.
http://newjersey.craigslist.org/pts/1449823079.html
here is exactly where i got them:
2003 e500
2003 e500
Administrator
A first clue should've been the fact that he shows a side pic with 19" tires on a E55. Second clue is the fact that he shows 2 different center caps. I'm with the rest, they appear to be replicas.
2003 e500
just found the post of the one i bought they have that gunmetal finish but the other center caps because i didn't buy the tires of of him
http://newjersey.craigslist.org/pts/1449825993.html
2003 e500
besides the way it looks is it going to effect car. and thanks for everyones help
2003 e500
also is there any way to make it work thanks
You can try to add a spacer. Depending on how much room you need inside that little cavity, you can purchase hub-centric spacers. Maybe a 3mm or 5mm will be enough for your needs. This essentially increases the offset of the wheel.
2003 e500
will i need longer lug nuts and if i don't do this right away will it effect the car
Best to try to see if you can get your money back and buy proper wheels. I know it sucks, but these cars are already so finicky that anything you put them that's not a high quality or OEM part really pisses them off.
