E-Class (W211) 2003-2009
Blower Regulator Replacement - Now become direct!
Old Nov 28, 2009 | 01:46 AM
ap10046's Avatar
CLS500 M113
About a week ago, my ac blower just went dead..the lights were there but 0 airflow from the vents..I could make out the compressor switching on.
I was then told it was the Blower Regulator that was shot.
So I ordered a new one..this...
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Now the blower works, the fan speed control works but the on/off doesn't work. If the ignition is on, the blower is on, ignition off, blower off..!!
What would you guys do??
Old Nov 28, 2009 | 09:03 AM
ap10046's Avatar
CLS500 M113
Ok..It gets better, the blower comes on but doesn't go off..even when the key is removed from the ignition!!
Old Nov 28, 2009 | 10:33 AM
vettdvr's Avatar
03 E500 and Corvette
Makes sure you don't have the residue a/c button depressed. It keeps the a/c blower motor on.
Old Nov 28, 2009 | 12:06 PM
Barry45RPM's Avatar
2015 ML 350
"REST" button is what he's refering to. It should be off.
Old Nov 28, 2009 | 01:16 PM
MB211's Avatar
2005 E500, 2011 ML350
I would assume you have a defective regulator? Maybe getting a regulator for 50% of OEM cost means 50% of OEM quality.......
Old Nov 29, 2009 | 08:57 AM
vettdvr's Avatar
You are correct!
Old Oct 26, 2015 | 10:38 PM
nivram13's Avatar
E240 -2003 E55 AMG -2005
I'm having the same issue purchased two "OEM" regulators from Ebay from two different sources both just cause the blower to run a full speed even with the ignition turned off!!
Plugged blower back into original Behr regulator(9140010471) and stops blowing constant which works intermittent which is why I need to replace it, but at least I can stop the blower running.
Has anyone else had problems with these aftermarket regulators? I'm now looking for an original Behr regulator are there any differences or variations between the part number that would cause the blower to run constantly when replaced?
The only obvious thing I can see is the difference is the capacitors on the two regulators could this be the problem?
Original regulator
Aftermarket regulator
