E-Class (W211) 2003-2009
Check Engine light HELP!
Old Dec 9, 2009 | 10:41 AM
MasterMoparSB's Avatar
A few toys & 07' E350 4matic w/AMG sport packg.
Alright well it's a ****ty rainy day here in NYC, went out to L.I. and within 5 minutes of starting the car and leaving the house the CHECK ENGINE light came on. Car drives/feels fine. I drove in traffic the whole way then when I go to my destination I called my local MBZ service, they said it might be a minor faulty bulb or a loose gas cap. I took the gas cap out and retightened it, but haven't gotten a chance to drive it yet to see if it went away. I knew someone who has a ML320 and had the same issue with the gas cap, but we'll see.
Anyhow, is there anyway to OBD read without a scanner? I know in my 02' Dakota I don't need a scanner to check computer codes, it's just a simple key trick. Tried it on the Merc but no luck, anything?
Old Dec 9, 2009 | 11:42 AM
Benz-O-Rama's Avatar
Nope, need a scanner. Just go down to your local AutoZone. They'll hook theirs up for free and give you the fault code.
Old Dec 9, 2009 | 01:20 PM
ohlord's Avatar
It won't be
a faulty bulb.
Get the code per above or if you want to diy get a scanner for your tool box. They are only 50 bucks at www.harborfreigt.com
It can be a loose cap(emissions system leak)
or a maf related code or if you have 100k miles on the car or more an oxygen sensor related code. You won't feel a lot of them but that does not mean they are not affecting performance or if ignored won't toast a cat converter.
Get the codes and post them. Do not go to the dealer,it can be resolved here.
Old Dec 9, 2009 | 04:45 PM
Originally Posted by ohlord
a faulty bulb.
Well damnit lol. On my lunch break I went to start the car and it was dead, and would not start, but just crank. A friend of mine had the power outlet-power outlet jumper thing and I did that and it worked. It now starts/runs perfectly fine but there is still a check engine light. I went to the dealer and made an appointment for monday morning and they'll give me a loaner car.
What should I do?
Old Dec 9, 2009 | 05:00 PM
SZMB's Avatar
2004 E500 CLK320
your car is under warranty. Let the dealer take care of the problem.
Old Dec 9, 2009 | 05:03 PM
That's what I though, plus that dealer is INCREDIBLE. And don't mind driving a free car
Old Dec 9, 2009 | 05:23 PM
Just went outside to move the car...the damn CEL is not on anymore.
Old Dec 9, 2009 | 05:59 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
damn gremlins always messing with the check engine light. i think they have become more of a nuisance than something of use. lol, when i had my 94 s420, the check engine light was on for so long that the bulb died out lol
Old Dec 9, 2009 | 06:23 PM
LoL. So I guess all is well? I will drive it the rest of the week and see what happens.
Old Dec 9, 2009 | 10:13 PM
fortlaudsummer's Avatar
W211 Elegance Saloon
Keep us posted!
Old Dec 9, 2009 | 10:30 PM
gaazmon's Avatar
Originally Posted by fortlaudsummer
Keep us posted!
+1
Old Dec 10, 2009 | 08:10 AM
Clinton Horn's Avatar
2003 E320
The car has stored the fault. The only code that I know of that "heals" itself is the gas cap. It takes a number of ignition cycles for the ECU to remove that problem so in your case that sounds doubtful. As others have mentioned, OBDII scanners are really reasonable. I purchased one for $40 at Costco. They allow you to clear codes but the car will re- post them if the problem is chronic. If you are really into it, you can get a cable and program for your laptop that provides complete information. The problem will likely return. I would find a scanner and get hard info.
Old Dec 10, 2009 | 04:59 PM
Yea drove the car today, no light. Not sure what the hell that was about. My feeling was a dead battery, and it recharged itself since I've been driving.
Old Dec 12, 2009 | 01:03 AM
Well, it just came on again.
Old Dec 14, 2009 | 08:28 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
Get the codes read and post them here -- like Clinton mentioned, there are several emissions sub-systems that need 2-3 drive cycles before the light comes on/goes out. The EVAP system typically needs 2-3 drive cycles to test with additional conditions (i.e., 15-85% gas in tank) before it will test. The EGR system is another that requires multiple drive cycles.
Regards,
paul...
Old Dec 14, 2009 | 11:39 AM
Regards,
paul...
Honestly, I don't want to bother with it. It's under warranty and I get a loaner C-Class so who cares. I'm brining it in in 4 hours. I'll find out later tonight or tomorrow what the situation is.
Old Dec 17, 2009 | 10:53 PM
Alright well, to wrap it up:
-I got a 08 C300 4matic sport loaner, black/black, was a great car. I was impressed.
-I paid $0 for service, all under warranty. I ended up giving the worker $5 tip, and put $17 gas in the loaner (I drove it a lot)
-Dealer treated me GREAT, beautiful place & great people.
-They replaced and adjusted crankshaft sensor
-They replaced intake cam solenoid (forget which side)
-They left my battery on a charger overnight
Car is 100% tip top and I noticed it feels a bit more powerful, or peppy
Old Oct 31, 2011 | 03:23 PM
Super rough idle, CEL and bad smell today....
Any ideas?
Old Oct 31, 2011 | 04:13 PM
Code is P 0022
Old Nov 1, 2011 | 10:49 AM
vettdvr's Avatar
03 E500 and Corvette
Camshaft hall effect sensor. Don't know how you adjust a bolt on part? If it was adjusted my guess it is defective and you need a new one. Total failure will park the car.
Old Nov 4, 2011 | 01:07 PM
CEL and everything went away on it's own...I'll pick up the magnet next time.
