Brake replacement ?
The OEM stuff will be proper spec although it may not have the eye candy appeal of being slotted, drilled, frozen and so on. The stock brakes have more than enough capacity unless you're racing and if you're racing a non-AMG 211 you should probably stop. on a problem continuum of maybe warping at one end and a rotor blow up at the other, stock is probably a good idea.
